Putting Maggie to work
6 replies to this topic
#1 Bwinkle7 OFFLINE
Bwinkle7
  • 45 Thanks
  • 26 posts
Posted September 27, 2015 - 04:52 AM
Morning,,,yeah I know it's 0530, couldn't sleep AGAIN. Anyway here are a couple pics of my 73 at work. That is my way of moving railroad ties without much effort. ??? Seems like I need to choke each time I start the engine. Is that normal? Also if I hold the lever of the hyd control all the way up, the hydraulics don't do anything, up or down, is that normal? GM
  • Alc, KennyP, Traill95 and 4 others have said thanks
#2 KennyP ONLINE
  • 38,243 Thanks
  • 45,876 posts
Posted September 27, 2015 - 05:29 AM
Neat tie mover! Sounds like you have a float position in that valve.
  • boyscout862 and Bwinkle7 have said thanks
#3 Alc ONLINE
  • 6,883 Thanks
  • 7,459 posts
Posted September 27, 2015 - 05:32 AM
Nice to you using your tractor for some heavy pulling ! As far as the hydraulics not sure if I'm following you but if the problem happens only when the spool on the valve is being pulled out , making it go further in the valve sealing off the posts . There might be a loose screw under the end cap on the oppsite end of the handle . There should be at least one spring that the screw in holding in place . Hope this makes sense .
#4 Alc ONLINE
  • 6,883 Thanks
  • 7,459 posts
Posted September 27, 2015 - 05:35 AM
What Kenny mentioned would be as the spool is being pushed in . It should lock in that position too. After thinking its more likely that , less common to happen what I posted.
Edited by Alc, September 27, 2015 - 05:43 AM.
#5 MH81 OFFLINE
Posted September 27, 2015 - 07:03 AM
Nice use of the GT and the old noodle with that mover.
It's been my experience that some engines are just like some people... They beg to be choked.
  • KennyP, boyscout862 and TomLGT195 have said thanks
#6 MNGB OFFLINE
MNGB
  • 2,105 Thanks
  • 1,402 posts
Posted September 27, 2015 - 07:43 AM
Its pretty normal to use choke at startup and I agtree your mov ing the control valve into the float position.
#7 Bwinkle7 OFFLINE
Bwinkle7
  • 45 Thanks
  • 26 posts
Posted September 29, 2015 - 05:07 AM
MH81,,,I needed a way to move those ties by myself. Ratchet straps are a very nice invention. As for your second statement, I must agree
