1320 hydro help
1 reply to this topic
#1 timothy OFFLINE
timothy
  • 32 posts
Posted April 13, 2011 - 09:25 PM
it does not seem to go but a turtles pace in rev even at full throttle forward seems to be fine but rev barely works. is there any adjustments??
#2 olcowhand ONLINE
  • 42,434 Thanks
  • 31,812 posts
Posted April 13, 2011 - 09:41 PM
If when the lever IS in the neutral position and the tractor IS truly in neutral, then nothing is out of adjustment and likely the hydro is just worn bad. I had a 1320 in same condition, so I cut the reverse slot in the dash a little deeper to give a longer reverse throw. It got by another 2 years before it finally gave up the ghost.
  • timothy said thank you
