new owner of a super a
3 replies to this topic
#1 thadscub OFFLINE
thadscub
  • 73 Thanks
  • 86 posts
Posted September 25, 2015 - 09:02 PM
hi guys i have purchased a 1950 super a with a snowplow and chains$ 1600 was running needed the fluid changed and when i went to start it today the starter wouldn't turn the engine over and  started smoking where is the best place to purchase a new starter would 12 volts thru a 6 volt starter fry it as it as it was converted to 12 volt also need the long arm to run a 3 point as  will be purchasing one soon thanks thad
  • Coventry Plumber said thank you
#2 nbent ONLINE
nbent
    customizer
  • 679 Thanks
  • 540 posts
Posted September 25, 2015 - 11:20 PM
That starter will be fine on 12 v I would check around and see if there is a place close that can rebuild it.
  • Coventry Plumber and Marty'70 have said thanks
#3 Marty'70 OFFLINE
Marty'70
    I didn't do it! Unless you have paperwork to back it up
  • 878 Thanks
  • 724 posts
Posted September 26, 2015 - 02:04 PM
Usually alot cheaper around here to rebuild rather than buy new.
#4 adamjd200 OFFLINE
adamjd200
  • 2,119 Thanks
  • 2,223 posts
Posted October 26, 2015 - 12:07 PM
12v shouldn't hurt the starter at all, I currently have a 12v batt. in my super c with no charging system (was like this when I got it) and it works fine, I plan to change it back to 6v with a 8v batt. eventually.
