Looking for clutch ideas
7 replies to this topic
#1 petrj6 OFFLINE
petrj6
  • 4,084 Thanks
  • 2,369 posts
Posted September 25, 2015 - 07:17 PM
     I am thinking on another project and need a few ideas, wanting to hook and engine to a rear diff with a driveshaft sort of like a cub cadet.  I want it geared up to build up speed not power.  this will be a horizontal engine to a rear diff with input shaft in the front.  for that reason I don't think a cub cadet clutch will work as I want it geared up.
        Pete
#2 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted September 25, 2015 - 09:42 PM
You can change the gears so as to have less torque and more speed but you run into trouble with gaining ground speed. Have you thought of using the tranny and rear of say a three wheeler? What is it you want to build I may have some things laying around?
#3 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted September 25, 2015 - 09:58 PM
It would really help to know what you want to build.
The simplest clutch is a simple belt and pulley arrangement, it's a tried and true setup that has been used for generations.
It really depends on what you want for a finished product
#4 KennyP ONLINE
  • 40,943 Thanks
  • 47,131 posts
Posted September 26, 2015 - 04:17 AM
I take it you aren't using a hydro?
#5 petrj6 OFFLINE
petrj6
  • 4,084 Thanks
  • 2,369 posts
Posted September 26, 2015 - 04:49 AM
   I have the engine and a standard rear trans out of a gt, the trouble I am running into is when I get the frame done and bolted to the rear diff the two will line up shaft to shaft.  of course I will need a driveshaft, that is why I was thinking about a cub cadet clutch setup but that is direct drive and I want it geared up.  I was thinking about using a gear reducing setup of a briggs engine just turn it around so It geared up rather than down, I just need to find one and then use a cub style clutch behind that.
        Pete
#6 KennyP ONLINE
  • 40,943 Thanks
  • 47,131 posts
Posted September 26, 2015 - 05:36 AM
There is a B&S with the gear reduction here, but it is not mine. Not sure how you can accomplish what you plan, but sounds like a fun toy.
#7 petrj6 OFFLINE
petrj6
  • 4,084 Thanks
  • 2,369 posts
Posted September 26, 2015 - 10:13 AM
     Turn the gear reduction around, it would require a bit of machining but that would increase the speed of the output shaft considerably !!!   maybe even to fast.  I am probably going to go with a belt clutch I was just looking for other ideas.
        Pete
#8 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted September 26, 2015 - 10:32 AM
If you really want to keep the shafts aligned, run a double belt clutch  to a jack shaft and chains back to the driveshaft. You could put whatever sprockets you wanted on it.
  • Alc and petrj6 have said thanks
