HP Win7 Machine problems
phenom windows 7 bfh
46 replies to this topic
#16 HDWildBill OFFLINE
  • 8,984 Thanks
Posted October 23, 2015 - 09:47 AM
Are you using the same HDD?  What made you decide to replace the MOBO instead of the HDD?
#17 Trav1s ONLINE
Trav1s
  • 3,581 Thanks
  • 4,557 posts
Posted October 23, 2015 - 01:05 PM
I have another HD too.  changed the board as i got a great deal on another that I have much experience with that will allow the Phenom to really do its thing.
Edited by Trav1s, October 23, 2015 - 01:07 PM.
  • HDWildBill said thank you
#18 Trav1s ONLINE
Trav1s
  • 3,581 Thanks
  • 4,557 posts
Posted October 23, 2015 - 03:40 PM
So the Phenom really kicks on this used board which is a Gigabyte GA-MA78GPM-DS2H.  Video is much better due to the nVidia chipset and dedicated 128Megs of video ram on the board.   Windows installed on a standard HD in less that 20 minutes.
#19 Trav1s ONLINE
Trav1s
  • 3,581 Thanks
  • 4,557 posts
Posted October 23, 2015 - 05:45 PM
Entered the Win7 key and it auto activated online.  I thought the copy of Windoze was tied to the MOBO but it seems it is tied to the processor.  Since I kept the Phenom 9150e processor from the old HP board all is good.  Now I am working to force updates and sort out those "wanted" and "unwanted" updates.
#20 HDWildBill OFFLINE
  • 8,984 Thanks
Posted October 24, 2015 - 10:23 AM
Hmmm,  I thought the key was made up of information from the HD, memory and the processor.  I guess not!  Glad to see you have it up and running.  Doing updates now is going to be a PITA for sure to sort out the good from the bad.
#21 Trav1s ONLINE
Trav1s
  • 3,581 Thanks
  • 4,557 posts
Posted October 24, 2015 - 11:02 AM
I suspect that MS loosened up requirements in light of Win10... but cannot confirm it.
I downloaded SP1 and installed it.  Now WinUpdate will not work.  I did some digging and this is a common problem with some machines.  Once I figure it out I will share my process with the forum.
  • MH81 and HDWildBill have said thanks
#22 Trav1s ONLINE
Trav1s
  • 3,581 Thanks
  • 4,557 posts
Posted October 24, 2015 - 08:17 PM
I ended up doing a restore to the first restore point created then forced it to update.  Installed 39 updates, then another 18, and then SP1 without a problem.  Installed a few more things and now I am in the same place.  Grrrr
#23 MH81 OFFLINE
  • 29,979 Thanks
Posted October 25, 2015 - 05:32 AM
Big hammer?
#24 Trav1s ONLINE
Trav1s
  • 3,581 Thanks
  • 4,557 posts
Posted October 25, 2015 - 07:26 AM
Big hammer?
The owner of the machine suggests a .357 or a .45.  I was thinking about driving my Jeep over it...
I got more updates to install then something else installed and stopped the updates.  Grrrr....
Edited by Trav1s, October 25, 2015 - 08:18 AM.
#25 HDWildBill OFFLINE
  • 8,984 Thanks
Posted October 25, 2015 - 09:59 AM
It sounds like there is an update that isn't getting along with your hardware.
#26 Trav1s ONLINE
Trav1s
  • 3,581 Thanks
  • 4,557 posts
Posted October 25, 2015 - 12:44 PM
Yeah but which one is the question.  My suspicion is the problem is MS Security Essentials...
#27 HDWildBill OFFLINE
  • 8,984 Thanks
Posted October 25, 2015 - 03:10 PM
Uninstall it and see if your problem goes away.  When did all this start?  Might have something to do with the Windows 10 upgrade.
#28 Trav1s ONLINE
Trav1s
  • 3,581 Thanks
  • 4,557 posts
Posted October 25, 2015 - 09:06 PM
I tried the uninstall, then I tried restore, and restore again.  Finally I grabbed the Win7 DVD and reinstalled windows.  This time I payed attention to what installed and when the update failed.  With a MS troubleshooter I found I discovered the "0x80070057" error and will work on resolving it tomorrow.  I swear I have had less MANY problems running multiple distros of Linux that with Win7 as of now...
But this is not my machine... and others do not deal well with change.
#29 HDWildBill OFFLINE
  • 8,984 Thanks
Posted October 25, 2015 - 10:56 PM
Sure hope you are getting paid for all this trouble.  Yea it is much easier to TS in Linux especially a Debian distro with apt and the command line.
#30 OldBuzzard OFFLINE
OldBuzzard
  • 7,097 Thanks
  • 4,816 posts
Posted October 26, 2015 - 09:11 AM
This is the first time I've looked at this thread.
The symptoms you have been describing are pretty much classic for a weak/failing Power Supply Unit.
  • Trav1s said thank you
Also tagged with one or more of these keywords: phenom, windows 7, bfh
