Service Manual for 1476
16 replies to this topic
#16 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 5122 Thanks
  • 2911 posts
Posted September 26, 2015 - 11:23 PM
That is why I need the diagram of the internal positions of the OEM switch.  Most wiring diagrams show that but not for the 1476.
OK - Here goes:
The 1476-01 uses the # 1721409 ignition switch, which was also used on several models of the tube-frames.
Look at the 1476-01 wiring diagram here.
The switch terminals are marked: S - B - A - Y - X
The internal connections for the # 1721409 key switch are:
Position 1 (OFF) no connections made
Position 2 (RUN) A+B connected together  also   X+Y connected together
Position 3 (START) B+S connected together  also  X+Y connected together
  • 29 Chev said thank you
#17 chieffan ONLINE
  • 16594 Thanks
  • 9089 posts
Posted September 27, 2015 - 07:30 AM
Hi Bruce.  Thank a ton for this information.  Now I can go searching for a switch that will match up those connections.  I have one for the 1053 from Napa but don't remember the Bolens part number right off.  The NAPA number is 7-01854.  I put it on a year ago and has worked fine ever since.  Cost me $14.  Only thing when going this route one has to remove the wires from the block and re-arrange them to the switch.  I think most that have tried this just use the block and plug it on the switch and the start don't work that way.
Will let you know when and if I come up with something.  The 1053 information was in a topic back in Nov. of 14  "Coil Wired Backwards And It Still Ran".
Thanks again,
Rog
