Service Manual for 1476
16 replies to this topic
#1 chieffan OFFLINE
  • 10,197 Thanks
  • 6,657 posts
Posted September 23, 2015 - 03:44 AM
Looking for a service manual for a 1476, or a 1455 which is nearly the same.  They are not included in the large frame service manual in the manuals section.  It starts with the 1800 series and on up for the later models.
#2 boyscout862 OFFLINE
  • 12,866 Thanks
  • 9,179 posts
Posted September 23, 2015 - 06:31 AM
I've used the manual we have in the Manuals Section for my 1250. It is pretty close for alot of things that I needed. Good Luck, Rick
  • chieffan said thank you
#3 chieffan OFFLINE
  • 10,197 Thanks
  • 6,657 posts
Posted September 23, 2015 - 06:50 AM
I found a partial in the Misc manuals section.  About 25 pages or so.  Will check out the manual for the 1250.  The 1455 should be the same or real close to the 1476 but didn't find it either.
#4 chieffan OFFLINE
  • 10,197 Thanks
  • 6,657 posts
Posted September 23, 2015 - 09:19 AM
Thanks but your 1250 is a tube frame where the 1476 is a large frame and about 20 years newer.  Not think there is much in common between the two besides motor, wheels and a steering wheel.
#5 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted September 23, 2015 - 09:26 AM
No, the 1250 was the first Large-Frame Bolens tractor.  ...It was introduced in 1967.
In 1969, the 1455 was introduced, and in 1970, the 1476.
#6 LPBolens OFFLINE
LPBolens
  • 1,415 Thanks
  • 971 posts
Posted September 23, 2015 - 09:54 AM
Bolens never published a complete service manual for the earlier Large Frames powered by the Wisconsin singles. They are really not that complicated. If you have the operating manual for the tractor, a manual for the Wisconsin engines and a manual for the Eaton 12 hydro, you have covered most of the tractor.
  • WrenchinOnIt, boyscout862 and chieffan have said thanks
#7 Rainier OFFLINE
Rainier
  • 507 Thanks
  • 474 posts
Posted September 23, 2015 - 10:42 AM
I have an illustrated parts catalog for 1476-01. Add an operators manual. Also have a 1477 manuals.
#8 chieffan OFFLINE
  • 10,197 Thanks
  • 6,657 posts
Posted September 23, 2015 - 09:33 PM
Your right, the 1250 was a large frame.  I was thinking 1050.
#9 chieffan OFFLINE
  • 10,197 Thanks
  • 6,657 posts
Posted September 23, 2015 - 09:35 PM
What I really need is the wiring diagram for the 1476.  No ignition switch and just several wires, loose end that attach to the switch I would guess.  I could probably figure it out OK but would be much easier and faster with a diagram.
#10 Rainier OFFLINE
Rainier
  • 507 Thanks
  • 474 posts
Posted September 23, 2015 - 09:40 PM
I'll dig thru my books and see what I can come up with.
#11 chieffan OFFLINE
  • 10,197 Thanks
  • 6,657 posts
Posted September 24, 2015 - 07:13 AM
I thought possibly the engine manual would have it but that only showed the ignition system, nothing else.  Large Frame Service Manual does not show it either.  With solid state ignition I don't want to blow it up, if it hasn't already been done.  I get kind of nervous with no switch and bear wires hanging around.
#12 Bruce Dorsi OFFLINE
Bruce Dorsi
  • 3,915 Thanks
  • 2,451 posts
Posted September 24, 2015 - 09:03 AM
Ask, and you shall receive!
I just added the 1476-01 Parts List with wiring diagram: http://gardentractor...bolens-tractor/
  • drbish and WrenchinOnIt have said thanks
#13 chieffan OFFLINE
  • 10,197 Thanks
  • 6,657 posts
Posted September 25, 2015 - 05:32 PM
Yes, I did see that.  Thank you much.  Be nice to have the internal contact points for the switch in the 3 positions like htere is for the tube frames.  thn I can match it up with a reasonably price ignition switch.
#14 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 2,956 Thanks
  • 2,105 posts
Posted September 25, 2015 - 07:04 PM
Watch what you do with the ignition switch,hooked up wrong,will fry the system
  • WrenchinOnIt and chieffan have said thanks
#15 chieffan OFFLINE
  • 10,197 Thanks
  • 6,657 posts
Posted September 25, 2015 - 07:14 PM
That is why I need the diagram of the internal positions of the OEM switch.  Most wiring diagrams show that but not for the 1476.
