What kind of oil for Hydraulics in New Holland S14
17 replies to this topic
#1 coinman66 OFFLINE
coinman66
  • 178 Thanks
  • 295 posts
Posted September 22, 2015 - 06:36 PM
Is it hydraulic fluid or 10w 30 that runs hydraulics?
#2 warren OFFLINE
warren
  • 59 Thanks
  • 46 posts
Posted September 22, 2015 - 06:40 PM
10w30.  I use in both engine and rear end.  (Hydraulics)
  • coinman66 said thank you
#3 shorty ONLINE
shorty
  • 5,288 Thanks
  • 5,169 posts
Posted September 22, 2015 - 06:41 PM
I think it is your 10-30 motor oil.
#4 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted September 22, 2015 - 06:43 PM
MS grade of 10-30 motor oil.
#5 coinman66 OFFLINE
coinman66
  • 178 Thanks
  • 295 posts
Posted September 22, 2015 - 07:01 PM
What is MS grade? Is it just normal 10w 30 motor oil?
Thank u.
Edited by coinman66, September 22, 2015 - 07:03 PM.
#6 coinman66 OFFLINE
coinman66
  • 178 Thanks
  • 295 posts
Posted September 22, 2015 - 07:02 PM
Thank u.
#7 coinman66 OFFLINE
coinman66
  • 178 Thanks
  • 295 posts
Posted September 22, 2015 - 07:03 PM
Thank u.
#8 chieffan OFFLINE
  • 9,609 Thanks
  • 6,427 posts
Posted September 22, 2015 - 08:00 PM
I use Northland Hydraulic oil in the hydro and hydraulics.  Same that is run in the big farm tractors.  If it can stand up in them it surly can't hurt the GT's.
#9 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted September 22, 2015 - 08:17 PM
Regular hydraulic oil in GT hydro could foam and cause cavitation. Very bad, and a warning on Case / Ingersoll tractors. Manufacturers specify certain oils for a reason.
Edited by wvbuzzmaster, September 22, 2015 - 08:18 PM.
  • shorty said thank you
#10 coinman66 OFFLINE
coinman66
  • 178 Thanks
  • 295 posts
Posted September 22, 2015 - 08:28 PM
So it's good old regular 10w 30 motor oil?
  • wvbuzzmaster said thank you
#11 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted September 22, 2015 - 08:40 PM
Ya, fairly unpicky. I would not run synthetic in it. I would put a good known quality brand of oil in though. I topped mine off (1/2 quart low) with leftovers of two 10w-30 and one 10w-40, it all dillutes with the rest. I plan to change it all in the Spring, but who knows.
#12 coinman66 OFFLINE
coinman66
  • 178 Thanks
  • 295 posts
Posted September 22, 2015 - 09:06 PM
And just fill it in the rear of tractor where the plug is? Thanks all for your help!
Edited by coinman66, September 22, 2015 - 09:09 PM.
#13 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted September 22, 2015 - 09:09 PM
Yes, that elbow in the back is the fill level, but not to the top, pretend it is level, if that makes sense.
Edited by wvbuzzmaster, September 22, 2015 - 09:10 PM.
#14 coinman66 OFFLINE
coinman66
  • 178 Thanks
  • 295 posts
Posted September 22, 2015 - 09:14 PM
Also I found my hydro plunger release thingy which I thought i lost. Tied a wire around it so I won't lose it again. If I wanna push tractor do I push the plunger in or pull it out? Actually I think there is something wrong with it cause it popped out in which I lost some oil. Maybe o ring needs replaced on plunger?
#15 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted September 22, 2015 - 09:18 PM
Push plunger in to free wheel, but you will have to remember to take the main lever our of park... Pulled out is engaged.
Was it you that had the plunger blast out? Sounds like a pressure relief wasn't working properly...
