How in the world did this happen?
18 replies to this topic
#16 TAHOE OFFLINE
TAHOE
  • 8514 Thanks
  • 5931 posts
Posted September 23, 2015 - 08:37 AM
The wire from the points should go to the negative side of the coil. Is it marked?
Yes it is, thanks you sir.
Does anyone know what the stud is for on the back of the points box? Does seem to be anything connected.
I guess points are grounded through block then over to coil?
Thanks Larry, that did help a little.
Edited by TAHOE, September 23, 2015 - 08:39 AM.
#17 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted September 23, 2015 - 08:41 AM
Is the stud truly a stud, or maybe more likely a much too long securing screw on the points or condenser?
#18 TAHOE OFFLINE
TAHOE
  • 8514 Thanks
  • 5931 posts
Posted September 23, 2015 - 08:54 AM
Maybe, haven't looked that far into it. I may investigate tonight or tomorrow.
I may have to just buy a new choke cable, cheap enough, this one is pretty froze up.
#19 TAHOE OFFLINE
TAHOE
  • 8514 Thanks
  • 5931 posts
Posted September 25, 2015 - 08:34 AM
....and as usual, you are right my good Sir. I popped open the point cover, that stud coming through the back holds the condensor and wire.
  • olcowhand said thank you
