SS12 scrapyard find
22 replies to this topic
#16 MH81 OFFLINE
  • 29,963 Thanks
  • 29,757 posts
Posted October 18, 2015 - 03:18 PM
Search for tickle test. It will tell you a lot.
  • Jazz said thank you
#17 Jazz OFFLINE
Jazz
  • 2,188 Thanks
  • 1,354 posts
Posted October 19, 2015 - 12:21 PM
What is a tickle test?
#18 TAHOE OFFLINE
TAHOE
  • 7,748 Thanks
  • 5,583 posts
Posted October 20, 2015 - 07:44 AM
holding the charge wire in your fingers while spinning flywheel to see if the stator is sending juice to the module.
You can also check the resistance of the charge wire with a meter
http://home.earthlin...toller/id9.html
There is an Ignition Charge Coil as part of the Stator under the flywheel.
It is very rare that they fail, but they have been damaged from cleaning and debris from loose flywheel magnets. It is possible that if the wrong type ignition key switch were installed and +12 Volts DC were applied by the kill switch wire instead of a ground that the Charge Coil may burn up. Before testing the Ignition Charge Coil, first disconnect the kill switch wire at the engine as above so it being grounded by the key switch will not give you miss leading information. To test this Ignition Charge Coil, measure the resistance between the engine block and the disconnected lead at the SSI. Figures 1-5, 20stator.jpg and 1-6, 20StatorCT .jpg show the 20 Amp Stator and associated circuit diagram for the 610906 SSI. The resistance of Ignition Charge Coil for the 610906 is Ohms 137 Ohms. The 10 Amp Stator for the 610748 is similar. You can also crank the engine and touch the terminal on the SSI and feel a tickle from the voltage pulses.
#19 motobreeder OFFLINE
motobreeder
  • 433 Thanks
  • 618 posts
Posted October 20, 2015 - 09:10 PM
Doesn't every good GT get two test tickles before it leaves the factory?
#20 Jazz OFFLINE
Jazz
  • 2,188 Thanks
  • 1,354 posts
Posted November 14, 2015 - 08:02 AM
Have not touched the Scracyard find but a fellow who was giving me some tires for a project showed me this. He bought new and now starter pooched. He's balking at the price of a starter so maybe he'll just go buy a new tractor.  Maybe I take it off his hands,,,help make room in his shed ya know...
Edited by Jazz, November 14, 2015 - 08:07 AM.
#21 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 283 Thanks
  • 229 posts
Posted November 14, 2015 - 01:09 PM
1973 st10 not a bad machine its a custom tractor close to 150 lbs lighter than a suburban. but will work hard
#22 John Arsenault ONLINE
John Arsenault
  • 2,060 Thanks
  • 1,060 posts
Posted November 26, 2015 - 09:26 AM
If he is balking at the price of a starter for this just wait till he catches wind on what they want for them there new tractors......lol
Though all my research I am finding that with these ignitions, its best to ditch the whole assembly and get a conversion kit when they fail. I have 3 hh120 engines right now but none of them are going back together with these old crispy components. I tried to fight the system and got one sparking after several hours of tinkering but after reading up on it , changed my mind and going with overnight solutions SSI conversion.
#23 Clifford B. OFFLINE
Clifford B.
  • 1 posts
Posted November 26, 2015 - 01:18 PM
   The great ones get three !!!............... :rolling:
