1966 j.d. 110 belt sizes
john deere garden tractor
9 replies to this topic
#1 case1man OFFLINE
case1man
  • 186 Thanks
  • 133 posts
Posted September 21, 2015 - 12:22 PM
Does anyone know what size belts are used on a 1966 john deere 110 round fender tractor. Bought one in pieces and it didn't have any belts on it.
#2 Trav1s ONLINE
Trav1s
  • 3,181 Thanks
  • 4,292 posts
Posted September 21, 2015 - 12:55 PM
Got a serial number?
if you go to www.jdparts.com, on left side of screen select "John Deere parts catalog"
When the new page opens up enter "110" in the box and select the "exact model search" option then select find
You will need 110/110H  (-100,000)
That should get you what you need.
Probably will need 3 belts for the tractor:
- starter/gen
- primary drive
- 2nd drive
Three belts for the mule/38 deck
- pto belt for mule drive
- mule to deck
- belt to drive blades
Edited by Trav1s, September 21, 2015 - 12:58 PM.
  • case1man said thank you
#3 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,750 Thanks
  • 4,244 posts
Posted September 21, 2015 - 01:11 PM
JDPC
#4 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
i can look in my my belt book at work(napa) i need the serial # for it or oem belt numbers ih ya have them before 5pm tonight
Edited by backwoods, September 21, 2015 - 01:12 PM.
#5 Trav1s ONLINE
Trav1s
  • 3,181 Thanks
  • 4,292 posts
Posted September 21, 2015 - 05:39 PM
M41335 - Starter Gen
M40015 - primary drive
M44121 - secondary drive
Intermediate drive/38 deck
M40637 - intermediate drive
M45998 - mower deck drive
M40223 - blade to blade
Edited by Trav1s, September 21, 2015 - 05:40 PM.
  • Bolens 1000 and case1man have said thanks
#6 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted September 22, 2015 - 11:22 AM
ok if i get a chance ill give ya napa numbers
#7 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted September 22, 2015 - 11:41 AM
So here are the following numbers that i have listed in the belt book at work
Factory              Napa
M41335           3L320W
M40015           5L350W
M44121           5L670W
M45998           4L830W
M40223           6532BR
M40637        Had no listing in the book nor would it cross to one of our numbers
#8 Trav1s ONLINE
Trav1s
  • 3,181 Thanks
  • 4,292 posts
Posted September 22, 2015 - 11:45 AM
M40637 is the belt that runs from the crank down to the drive.  The foot PTO assembly pulls it tight to engage the deck.  You can see it in this pic:
Edited by Trav1s, September 22, 2015 - 11:47 AM.
#9 Bolens 1000 ONLINE
  • 14,906 Thanks
  • 18,104 posts
Posted September 22, 2015 - 11:51 AM
I would suggest getting Genuine Deere belts, most of them are OEM spec size and material and many are raw edge belts it seems from my interchange
The napa cross for these is just giving you the closest fractional HP fan belt part number and are not rated for L&G applications
if you dont have any luck locally I can give you pricing on some OEM spec belts, the aftermarket company I use for Deere belts is actually Owned by Deere so they are basically the same thing just a cheaper price.
#10 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted September 22, 2015 - 12:10 PM
yea the belts i listed are from the lawn an garden book the not the fractional hp line. i know the belts we sell arent factory but if you cant afford a belt form a dealer theyll get ya by
Edited by backwoods, September 22, 2015 - 12:46 PM.
Also tagged with one or more of these keywords: john deere garden tractor
