Ht20d loader install and pump questions
36 replies to this topic
#31 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3727 Thanks
  • 2367 posts
Posted February 11, 2016 - 04:55 PM
Woops,correct,10 lbs per tire,I Crack the bead on the side of the valve stem,put a large screw driver in to hold the side wall down a little,pour the washer fluid in,release the screw driver an hit it with air,lot quicker than through the valve stem,OB thanks for the clarification on the amount,going to make the correction
Edited by blackjackjakexxix, February 11, 2016 - 04:56 PM.
#32 HT20D OFFLINE
HT20D
  • 35 Thanks
  • 19 posts
Posted February 11, 2016 - 05:49 PM
FYI
I just put together a thread over in the implements section about the Terra-blade.
  • LPBolens, blackjackjakexxix and AA Hayes have said thanks
#33 HT20D OFFLINE
HT20D
  • 35 Thanks
  • 19 posts
Posted February 11, 2016 - 05:51 PM
I did realize filling the tires added up to that much weight. I'll check out the rimguard. I might look at getting some new more aggressive tires before I fill them, these are pretty weather cracked and it could use some more traction.
Thanks for all the info!
#34 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted February 11, 2016 - 10:21 PM
If you are looking for new aggressive tires, I can highly recommend the CST Ancla ATV tires.
I have them on three of my large frames and really like them.
They are great for traction, and a lot cheaper than the more traditional R1 Ag tires.
I get mine from here: http://www.discountu...-ATV-UTV-TIRES/
Not to mention that they use a Husky dog as part of their logo, so they are perfect for a Bolens :D :D :D
  • blackjackjakexxix and HT20D have said thanks
#35 LPBolens OFFLINE
LPBolens
  • 1461 Thanks
  • 979 posts
Posted February 11, 2016 - 11:29 PM
If you do install ATV tires, be aware that some of them will not clear a mowing deck on a Large Frame when the deck is lifted up. (Don't ask how I know this please)
  • blackjackjakexxix and ClassicBolens have said thanks
#36 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted February 12, 2016 - 01:31 AM
Which  ATV tires did you have on it?
I don't see why ATV tires would make a difference as long as they were the same size as the ones they replaced.
#37 LPBolens OFFLINE
LPBolens
  • 1461 Thanks
  • 979 posts
Posted February 12, 2016 - 01:50 AM
Many of them may be the same nominal size, but have much taller tread, and tend to have a rounder contact patch. That was where I ran into problems on a 1455. It is possible that with the slightly different dimensional positioning of a deck on the later LF's, there might not be the same interference.
