Picked up nice little Simplicity 4212
11 replies to this topic
#1 MNGB OFFLINE
MNGB
  • 2,494 Thanks
  • 1,523 posts
Posted September 19, 2015 - 08:18 PM
Hi all, found a 88 Simplicity 4212 hydr on CL $50.00 seller said the engine needs work, went and looked at it he said the rod went and he got a used rod installed it and after he got all back together it would barely turn over with a wrench on the flywheel nut. Since I had and exact same engine in the shop I bought it and installed my engine after some carb work got it running good the hydro is really nice a crisp drove it around for some test running and late this afternoon decided to install the deck that went good but I discovered the linkage for lifting the deck was missing called the seller and he said he never had it so after looking in the owners manual I kind of got an idea of how it should be and fabricated some linkage and it lifts but will not remain in the up position, I'm thinking its suppose to over center but it doesn't quite go over center. Anyone have experience with the lift assy and know how its suppose to work?
  • Alc, TomLGT195, HANKG and 1 other said thanks
#2 CraftsmanGT OFFLINE
CraftsmanGT
  • 227 Thanks
  • 267 posts
Posted September 19, 2015 - 09:13 PM
I've got the Allis equivalent to that. You'll love it, they are tough little tractors. Same frame as an Allis 808GT/810GT/811GT/816GT
  • MNGB said thank you
#3 CraftsmanGT OFFLINE
CraftsmanGT
  • 227 Thanks
  • 267 posts
Posted September 19, 2015 - 09:16 PM
#4 MNGB OFFLINE
MNGB
  • 2,494 Thanks
  • 1,523 posts
Posted September 19, 2015 - 09:26 PM
Hi CraftsmanGT, thanks for the replies and the picture, what I made looks very close but with a shorter rod maybe I need to lengthen the rod in the fork, does the rod just attach to the lift lever arm?
Yes I think I'm going to like it very solid well built tractor I know that Simplicity's really mow nice.
#5 CraftsmanGT OFFLINE
CraftsmanGT
  • 227 Thanks
  • 267 posts
Posted September 19, 2015 - 09:46 PM
Yes, mine is a 90 degree bend with a nut that holds it on to the lift lever. You could use a cotter pin too
#6 TomLGT195 OFFLINE
TomLGT195
  • 4,018 Thanks
  • 2,884 posts
Posted September 20, 2015 - 06:45 AM
That looks in great shape, nice score!
#7 MNGB OFFLINE
MNGB
  • 2,494 Thanks
  • 1,523 posts
Posted September 20, 2015 - 04:53 PM
Hi CraftsmanGT, a big thanks for the picture of the lift link, went into the shop this afternoon (after the game) and fabricated one like your picture shows and happy day it works had to tweak the lift lever a bit also. :bounce: :beerchug:
#8 CraftsmanGT OFFLINE
CraftsmanGT
  • 227 Thanks
  • 267 posts
Posted September 20, 2015 - 06:08 PM
Glad to hear. If you have anymore questions just ask
#9 CraftsmanGT OFFLINE
CraftsmanGT
  • 227 Thanks
  • 267 posts
Posted September 20, 2015 - 07:52 PM
Also, how do you like the hydro? Mines a 5 speed
#10 MNGB OFFLINE
MNGB
  • 2,494 Thanks
  • 1,523 posts
Posted September 20, 2015 - 08:05 PM
I really like it I have a couple other Husqvarna's and a Craftsman GT 5000 with hydro's when mowing a lawn its hard to beat a hydro. The hydro in the Simplicity is a good strong one and much stronger than the ones used in current lawn tractors.
#11 CraftsmanGT OFFLINE
CraftsmanGT
  • 227 Thanks
  • 267 posts
Posted September 21, 2015 - 03:05 PM
That's good to hear. I've never owned a hydro
#12 Old5088 OFFLINE
Old5088
  • 15 Thanks
  • 16 posts
Posted February 11, 2016 - 02:47 PM
attachicon.gifHPIM2134.JPGattachicon.gifHPIM2135.JPGattachicon.gifHPIM2136.JPGattachicon.gifHPIM2137.JPGattachicon.gifHPIM2138.JPG
Your pm with the information & link was a Great help - Thanks
