B10 wont stay running
28 replies to this topic
#1 DanP ONLINE
DanP
  • 326 Thanks
  • 490 posts
Posted September 18, 2015 - 12:24 PM
I have a restored 10 HP Briggs in my B10. I did this a couple years ago and rebuilt the carb. It starts fine but after it runs for 15-20 minutes it starts to die, the only way it will stay running is if you put the choke all the way on and then that only works for awhile. Any ideas?
#2 CRFarnsworth ONLINE
CRFarnsworth
  • 5,219 Thanks
  • 2,271 posts
Posted September 18, 2015 - 12:39 PM
Is the gas cap venting?    Next time take the cap loose and see if it happens again.
  • DanP, Talntedmrgreen and boyscout862 have said thanks
#3 boyscout862 ONLINE
  • 13,692 Thanks
  • 9,476 posts
Posted September 18, 2015 - 12:49 PM
The gas cap is the easiest to check. If that isn't it, you may have a clogged filter(in the tank) or a restricted fuel line. Unfortunately those gas caps through the hood invited several problems. Good Luck, Rick
  • CRFarnsworth and DanP have said thanks
#4 petrj6 OFFLINE
petrj6
  • 4,084 Thanks
  • 2,369 posts
Posted September 18, 2015 - 01:38 PM
Does the choke make a difference? I mean does choking it make it run longer or does it stay running the same either way? Are you running hi rpms or at an idle? If at hi rpms and it dies like that I would say your float is out of adjustment, if you are idling I would look at the coil and condenser, they may be getting hot and quitting
Pete
#5 Talntedmrgreen OFFLINE
  • 3,292 Thanks
  • 2,319 posts
Posted September 18, 2015 - 02:07 PM
Float adjustment would give these symptoms regardless of operating temp.  In addition to the suggestions above, when it begins running like junk, spray some starting fluid around the gaskets between the carb & intake, then intake and block.  Easy to pickup a vacuum leak here when warm.  Also, is your breather clean?
#6 chieffan OFFLINE
  • 11,779 Thanks
  • 7,284 posts
Posted September 18, 2015 - 03:15 PM
Definitely check that gas cap on the tank.  I had a 10hp Wisconsin in a Bolens 1053 that did the same exact thing.  It was the gas cap vent.  The cap had a fiber type liner for a seal.  When it go wet with gas it expanded and shut off the air supply to the tank.  Point of a sharp pocket knife blade to make the fiber hole larger and hasn't bothered since.  Good luck.
#7 karel OFFLINE
karel
  • 2,420 Thanks
  • 1,540 posts
Posted September 18, 2015 - 04:20 PM
IMG_2061.JPG I just went through the same issue you are having. I have a simplicity vc walkbehind with a brigggs model 19. the engine had been gone through as far as spark and no vent issues. but same issues as you. I put a carb kit in it. it runs nice now. use an oem kit.
Edited by karl, September 18, 2015 - 04:26 PM.
  • DanP said thank you
#8 DanP ONLINE
DanP
  • 326 Thanks
  • 490 posts
Posted August 08, 2016 - 09:11 AM
I played with this over the weekend. Since I put a new external coil on it and mounted it on top of the head I thought maybe the coil was getting hot. I ran it and watched it for a while and sure enough about 20 minutes it started to die. I checked the spark with a neon tester and it had spark right up until it died. The card has been rebuilt and the gas cap check for venting and it works fine. I could put a piece of clear tube in the gas line to see if it stops getting fuel but I don't know how that can happen. Any ideas?
#9 jabelman ONLINE
jabelman
  • 2,334 Thanks
  • 1,647 posts
Posted August 08, 2016 - 04:55 PM
I had similar issue on kohler, and changed out condenser, rebuilt carb, plug, chk points coil and so on. it turned out to be a connection. I since rewired the whole machine with new wires and problem went away
#10 DanP ONLINE
DanP
  • 326 Thanks
  • 490 posts
Posted August 09, 2016 - 08:39 AM
I re wired it when I restored it a couple years ago. It has new coil and condenser on it. Like I said I checked the spark as it was dieing and it had spark right up until it died.
#11 tater195 ONLINE
tater195
  • 2,288 Thanks
  • 1,455 posts
Posted August 09, 2016 - 09:46 AM
Did you switch to a 12v coil or do you still have a ballast resistor?
#12 DanP ONLINE
DanP
  • 326 Thanks
  • 490 posts
Posted August 09, 2016 - 10:34 AM
I have a 12 volt coil and resistor both are new.
#13 tater195 ONLINE
tater195
  • 2,288 Thanks
  • 1,455 posts
Posted August 09, 2016 - 10:49 AM
You shouldnt need the resistor if the primary is rated for 12v
#14 DanP ONLINE
DanP
  • 326 Thanks
  • 490 posts
Posted August 09, 2016 - 12:09 PM
I thought you had to either use a coil with a resistor in it or use an external resistor to knock the voltage down.
#15 tater195 ONLINE
tater195
  • 2,288 Thanks
  • 1,455 posts
Posted August 09, 2016 - 12:47 PM
The 12v coil should handle full power, resistors are sometimes added to keep from burning out the points.
Brian Millers page is confusing and contradicting. He says you dont need one then goes on to say you can add one, but not more than 1.5 ohms depending on the resistance of the coil. Then he adds a pic that says you dont need one for a 12v coil.
  • TomLGT195 said thank you
