anybody know the belt size
montgomery wards 16 variable
6 replies to this topic
#1 Reed Breneman ONLINE
Reed Breneman
  • 1,890 Thanks
  • 651 posts
Posted September 18, 2015 - 10:26 AM
I have looked thru the site but not found it yet(I may be blind so if it sticks out like a sore thumb you may hit it)I have a 74 mwards variable speed 16 and the belt from the hydro?to the rear end broke,and the belt for the hydraulic pump is also broke(belts were shot so just wore out and broke)There are only 3 belts on the machine and these 2 are located under the seat,just for reference
#2 cadyjames41 ONLINE
cadyjames41
  • 5 Thanks
  • 15 posts
Posted September 18, 2015 - 05:57 PM
What is your model number. I might have a parts list for you.
#3 PGHsteelworker OFFLINE
PGHsteelworker
  • 96 Thanks
  • 55 posts
Posted September 18, 2015 - 10:53 PM
I believe this should be for a 74 or 75.MW Parts (1).JPG MW Parts (22).JPG MW Parts (23).JPG MW Parts (26).JPG MW Parts (27).JPG
#4 Reed Breneman ONLINE
Reed Breneman
  • 1,890 Thanks
  • 651 posts
Posted September 19, 2015 - 08:34 AM
model number is a problem,there is no id numbers or plates to be found,there are pics of my tractor in the gallery,if i remember right someone called it a long frame
thank you
                        Reed
#5 Sprint 6 ONLINE
Sprint 6
  • 227 Thanks
  • 293 posts
Posted September 21, 2015 - 07:49 AM
Your tractor is not a hydro, it is gear drive. The Napa belt number for the trans belt that goes between the mechanical variator and the trans is 4L360W. The belt number for the hydraulic pump is 3L210W.
#6 PGHsteelworker OFFLINE
PGHsteelworker
  • 96 Thanks
  • 55 posts
Posted September 21, 2015 - 08:14 AM
Thanks for the part numbers.
Edited by PGHsteelworker, September 21, 2015 - 08:18 AM.
#7 Reed Breneman ONLINE
Reed Breneman
  • 1,890 Thanks
  • 651 posts
Posted September 23, 2015 - 08:41 AM
yes thank you for the info,I have a lot to learn about these tractors
