bolens ek brake
4 replies to this topic
#1 Eric OFFLINE
Eric
  • 1324 Thanks
  • 813 posts
Posted September 18, 2015 - 02:05 AM
hello I have run into an issue, my EK brake just barely makes contact which makes getting in gear without grinding impossible. The pad is brand new and I don't see any adjustment, I was thinking of adding a shim. Any insight into my dilemma would be great THANK YOU!
#2 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted September 18, 2015 - 03:28 AM
I looked at the OOM, and you need to adjust the CLUTCH.
The procedure is the same fot the EK7 and EL10.
here's a link to the EK7 OOM:
http://gardentractor...-owners-manual/
See page 14 for that adjustment.
  • boyscout862 and Eric have said thanks
#3 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted September 18, 2015 - 07:30 AM
Like Oldbuzzard mentioned above you need to adjust your clutch petal cable
#4 BRIAN EK7&10 OFFLINE
BRIAN EK7&10
  • 262 Thanks
  • 112 posts
Posted September 18, 2015 - 07:54 PM
the link that connects the clutch lever to the idler arm has a hole at each end and a pin on the lever and idler arm that tend to get worn out and loose the link is easy enough to replace but the lever and icler arm are more involved
  • Eric said thank you
#5 Eric OFFLINE
Eric
  • 1324 Thanks
  • 813 posts
Posted November 12, 2015 - 07:15 PM
Issue resolved it sheared the pin on the pedal, was still hanging on so was not free turning. It is all back together and functions properly now thank you for all the help.
  • Bolens 1000 and Gtractor have said thanks
