Tires question
14 replies to this topic
#1 Nxt2doc OFFLINE
Nxt2doc
  • 628 Thanks
  • 334 posts
Posted September 17, 2015 - 12:11 PM
So the deal is, It's my birthday and I got hooked up with enough dead presidents to buy a set of tires for the Wheelhorse 1267. I'm looking at a set of Deestone bar treads. They will get typical pushing snow and around the house use No pulling or extreme use is planned.. Bar tread ags are my tire type choice. Are the Deeston's a reasonably good tire or should I look further
#2 tater195 OFFLINE
tater195
  • 2,200 Thanks
  • 1,413 posts
Posted September 17, 2015 - 12:42 PM
Check around on the net. places like miller tire or tucker tire will be alot cheaper than the local guys. usually you can get 26x12x12 (if you want to go that big) for around $100 for the pair. I have never used the deestones, but they are about half the price of carlisles, if that tells you anything
  • limebuzz said thank you
#3 olcowhand ONLINE
  • 41,261 Thanks
  • 31,447 posts
Posted September 17, 2015 - 12:55 PM
Deestone tires are decent tires, and I own some.  However, their sizes are way off.  They typically run 1" narrower, and one inch shorter than the same size tire in Carlisle or Titan.  Get the highest ply available if you go with Deestone, or any brand for that matter.
Duro, Kenda, and Nanco are other brands much cheaper than Carlisle.
  • limebuzz, KennyP and MolonLabe have said thanks
#4 Nxt2doc OFFLINE
Nxt2doc
  • 628 Thanks
  • 334 posts
Posted September 17, 2015 - 01:42 PM
This is what I am looking at
http://www.ebay.com/...=item5b1456b80a
The price seems pretty good to me for a set delivered.
  • olcowhand said thank you
#5 olcowhand ONLINE
  • 41,261 Thanks
  • 31,447 posts
Posted September 17, 2015 - 02:23 PM
I have those same tires on my restored Bush Hog D4-10. That size is close to identical size as Carlisle. Good tires.
#6 KennyP OFFLINE
  • 38,478 Thanks
  • 45,969 posts
Posted September 17, 2015 - 05:07 PM
Those should do fine for your intended purpose!
#7 twostacks OFFLINE
twostacks
  • 479 Thanks
  • 438 posts
Posted September 17, 2015 - 06:55 PM
I have those tires also. I think the tread depth is a little more shallow than the Carlisle tires and I agree with the tire sizes being off, but they work just fine otherwise. I purchased the 6 ply and I will never do it again. I put them on by hand and they were a real bear to get on and get seated.
#8 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted September 17, 2015 - 07:40 PM
     Look around a bit before you buy, check with summit.  they are offering free shipping on orders over $100, you may be able to get a set of cralisle shipped for reasonable.
                            Pete
#9 Nxt2doc OFFLINE
Nxt2doc
  • 628 Thanks
  • 334 posts
Posted September 17, 2015 - 08:23 PM
Have a buddy with a garage going to mount them for a few bucks a piece so not worried about having to muscle them on.
#10 JBRamsey ONLINE
JBRamsey
  • 1,474 Thanks
  • 841 posts
Posted September 17, 2015 - 08:35 PM
I don't see anything for a $ 100 a pair. What am I missing?
#11 tater195 OFFLINE
tater195
  • 2,200 Thanks
  • 1,413 posts
Posted September 17, 2015 - 09:40 PM
Check ebay. Several pair (8.50s) on now for under $100. The 12" wides dont pop up very often. I found 29/12.5/15s for $115 each afew years ago
#12 MolonLabe ONLINE
MolonLabe
    Rust Wrangler
  • 551 Thanks
  • 320 posts
Posted September 18, 2015 - 03:03 AM
I purchased a set of these http://www.ebay.com/...=STRK:MEBIDX:IT
from the same ebay seller for my 416-8, nice tires but a little on the small side for 23X10.50-12 as stated above.
#13 BNK OFFLINE
BNK
  • 1,095 Thanks
  • 495 posts
Posted September 18, 2015 - 07:12 AM
My first set of Deestones I purchased was 11 yrs ago, they came from Tuckertire,so did my second set a few yrs later. Traction with weights has impressed me but what impressed me the most is no dry rot is seen after 11 yrs of use. My Carlilse set 10.50 AGs show alot of sidewall checking and leak so I put tubes in that set. I must agree the stones are a little undersized.
#14 TAHOE ONLINE
TAHOE
  • 7,978 Thanks
  • 5,676 posts
Posted September 18, 2015 - 07:25 AM
Pretty much what the other guys said. I have a set on my Sears, 23x10.50, they measure 8.5" across tread and about 21.5" tall so they are smaller than advertised. For the $100 cheaper than Carlisles, I can deal with it.
They are the only ones I have ever used so I can not give a comparison. I've had them 3 yrs, loaded with washer fluid, no problems yet.
We discussed it a while back, may help your decision
http://gardentractor...r-bkt-ag-tires/
#15 BTS ONLINE
BTS
    Make Stuff Up
  • 4,267 Thanks
  • 2,462 posts
Posted September 18, 2015 - 08:12 AM
I have R4 tread style on my Bolens HT23, I really like them, they don't tare the grass up like a bar lug but yet they get good traction when I'm playing in the dirt. Tire chains also go on them nicer, the chains don't fall between the lugs.
