JD 318 herd
7 replies to this topic
#1 terdybukrat OFFLINE
terdybukrat
  • 1 Thanks
  • 3 posts
Posted April 11, 2011 - 08:37 PM
I have had a 1983 JD 318 for a few years now as my primary mowing machine and I love it. Recently, I picked up a '87 and '92 very inexpensive(read that as neglected) 318's that I hope to get working again. I'm curious about the hydros. I'm confident that I can get 1 or both of them running, but what should I be concerned about with the transmissions when I get the engines going? I know the fluid and filters will need changed, and one of them definitely needs relief valves. What would you do?
Thanks,
Terry
#2 Bolens 1000 OFFLINE
  • 14,987 Thanks
  • 18,140 posts
Posted April 12, 2011 - 07:58 AM
Sorry I cant help you with your question. Hopefully someone comes along soon that can give you a hand
#3 olcowhand ONLINE
  • 41,148 Thanks
  • 31,416 posts
Posted April 12, 2011 - 11:13 AM
Are the relief valves sticking? They can be taken apart & cleaned up if that's the case. Those hydro's are tough, so a good chance an oil & filter change & get the valves working, and you'd get years of great service.
#4 a4hope2011 OFFLINE
a4hope2011
  • 1 Thanks
  • 36 posts
Posted April 12, 2011 - 10:37 PM
There is also a source to get those relief valves new, but a good cleaning should get them back into working shape. It isn't from JD but it is a standard part available from another company, I just can't remember where right now. As others have said fluid and filter change and it should be alright for another couple decades.
#5 reddogdvd OFFLINE
reddogdvd
  • 1 Thanks
  • 3 posts
Posted April 22, 2011 - 11:08 AM
I say make it a learning experince. Take them apart!
#6 NUTNDUN OFFLINE
  • 10,340 Thanks
Posted April 22, 2011 - 12:26 PM
Nothing like learning by getting your hands dirty. I agree with what all has been said, the hydros are tough units and a good oil and filter change and they should be good to go other then cleaning the relief valves or replacing them if need be.
#7 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted April 22, 2011 - 07:38 PM
Congrats on the new tractors. 3 318's -Wow, they are rare in these parts. I don't think I have seen more than 3 of them in the last 5 years total. There are lots of the newer JD's but the older ones are not common at all. I just picked up a 314 and I have only seen 1 318 for sale in the last 6 months.
#8 jwill1776 OFFLINE
jwill1776
  • 1 Thanks
  • 12 posts
Posted May 01, 2011 - 10:04 AM
The 318 Hydros are fairly tough, I’d say change out the fluids and filters and run them. Unless you know there is a problem like your relief value. Some units have creep where they will creep forward even in neutral, I’m not sure there is a fix for that.
