About to Uload A Gardener
68 replies to this topic
#61 MH81 OFFLINE
Posted September 22, 2015 - 06:29 AM
Two kinds of coils
With Internal resistor and without.
Usually, with an internal resistive coil, you don't need the extra dropping resistor, some guys use them anyways if the points are a B to get to.
#62 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,288 Thanks
  • 9,776 posts
Posted September 22, 2015 - 06:32 AM
This has been a learning experience for all of us. The original problem was the factory coil not putting out enough?
  • chieffan said thank you
#63 chieffan OFFLINE
  • 10,122 Thanks
  • 6,626 posts
Posted September 22, 2015 - 07:59 AM
That is the best I can come up with.  The output coil to the points tested .5 ohms.  From what I was told when they get down to .7 they start causing problems.  A good coil will test about 1.2 to 1.4 ohms.  Just a break down with age and use I guess.
  • diesel nut said thank you
#64 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted September 22, 2015 - 08:00 AM
Yes.  .....Those B&S # 29656 "horseshoe" magneto coils were notorious for failing in that manner.
They would generate a spark, which was deceptive, yet they would not allow the engine to run, or run properly.
  • Alc and chieffan have said thanks
#65 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,288 Thanks
  • 9,776 posts
Posted September 22, 2015 - 08:08 AM
Remember when gas stations had those spark plug testers? You would screw in the plug and run up the pressure while it was sparking. Sparking is one thing. Sparking under compression is something else.
#66 chieffan OFFLINE
  • 10,122 Thanks
  • 6,626 posts
Posted September 22, 2015 - 08:14 AM
I just happen to have on of those.  Has the cleaner with it.  Bought it from a local Chevy garage when it closed.  I had an H Farmall at that time that would foul the plug on one cylinder every half day of running.  Would use the machine to clean up the plug and use it again the next day.  Had some stuck rings but finally got them loosened up.  Sure took a long time, like all summer.
  • Alc and LilysDad have said thanks
#67 Alc OFFLINE
  • 6,884 Thanks
  • 7,459 posts
Posted September 23, 2015 - 05:23 AM
Bruce would those ( or other coils ) fail like I have seen with plugs ? You would get a OK spark laying it on the head but nothing when installed ? Would an inline plug checker pick that up or maybe a 12 volt power timing light ?
#68 chieffan OFFLINE
  • 10,122 Thanks
  • 6,626 posts
Posted September 23, 2015 - 06:31 AM
Alc, I had an in line spark checker on this one and it showed spark.  I guess I should have turned the lights off and then watched it.  May have caught it sooner that it was a week spark but I didn't.  I did check with the lights off but was watching for a spark wwhere it shouldn't be and not at the spark checker.
#69 DougT ONLINE
DougT
    Dog Approved
  • 6,926 Thanks
  • 4,994 posts
Posted September 23, 2015 - 07:35 AM
That's why it isn't a good idea to check for spark outside the cylinder with a spark plug. You can make a tester out of a plug by making the gap too big. I use a rule of thumb of at least 5 times the plug gap outside the cylinder. If you can jump that, you should have a strong enough spark. I'v even closed the plug gap to compensate for a weak coil.
