3 point hitch help
16 replies to this topic
#1 Fdsinozich OFFLINE
Fdsinozich
  • 29 Thanks
  • 76 posts
Posted September 15, 2015 - 07:55 PM
Bought GT1855 with 3 point hitch, but I've never used one. I have some rods that I think go with the hitch. I bought a 3point receiver to pull my trailer. I don't know how to hook it up. Any pics or help would be helpful.
Thanks
#2 OldBuzzard OFFLINE
OldBuzzard
  • 7,097 Thanks
  • 4,816 posts
Posted September 15, 2015 - 09:27 PM
A couple of pics of what you have would help.
I use an A-Frame with a ball on it for moving my trailer:
  • limebuzz, WNYTractorTinkerer and CanadianHobbyFarmer have said thanks
#3 HALFSCALE OFFLINE
HALFSCALE
  • 515 Thanks
  • 537 posts
Posted September 16, 2015 - 02:49 AM
Is the bell crank bolted to the top/back plate, should have a clevis pin attatched to a flat rod that sticks out the back on left side
From there your lift arms attatch to the lower pins, then 2 threaded rods go through threaded swivels in bell crank and the lower end goes to lift arms. These are to ajust your offset height when plowing.
White offered 2 ways, you can get an  A frame like Old buzzard shows or White used a flat bar with 5/8 pins welded on ends to go between your lift arms and then hook your chains tight to limit sway.
#4 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1,179 Thanks
  • 697 posts
Posted September 16, 2015 - 03:31 PM
I have never seen an A-frame quite like that one, with the ball mount on one side and the sleeve hitch on the other. Did you buy it that way Old Buzzard or build it or modify an existing unit?
Jim
#5 OldBuzzard OFFLINE
OldBuzzard
  • 7,097 Thanks
  • 4,816 posts
Posted September 16, 2015 - 05:29 PM
I bought it from these fine folks.
http://www.ballardfa...cat0sleeve.html
They will add the 'tab' for and extra $15.00.
  • CanadianHobbyFarmer said thank you
#6 Fdsinozich OFFLINE
Fdsinozich
  • 29 Thanks
  • 76 posts
Thanks. I would love to show you what I have to work with, but I don't know how to add pics.
#7 OldBuzzard OFFLINE
OldBuzzard
  • 7,097 Thanks
  • 4,816 posts
Posted September 16, 2015 - 05:41 PM
Check out this page and you will be uploading pics in no time  :D :D :D
#8 Fdsinozich OFFLINE
Fdsinozich
  • 29 Thanks
  • 76 posts
Posted September 16, 2015 - 06:55 PM
Thanks, Old Buzzard but there doesn't appear to be a link to anything.
Maybe I'm missing it.
Thanks,
Frank
#9 OldBuzzard OFFLINE
OldBuzzard
  • 7,097 Thanks
  • 4,816 posts
Posted September 16, 2015 - 09:21 PM
DOH!
Forgot to paste it :(  :( :(
Here ya go:
http://gardentractor...file-uploading/
#10 Fdsinozich OFFLINE
Fdsinozich
  • 29 Thanks
  • 76 posts
Posted September 17, 2015 - 08:21 AM
OK, pic of Titon attachment, pic of tractor hitch and pic of items from box that came with tractor. May be others in the box I don't recognize. What do you think?
Thanks
#11 Fdsinozich OFFLINE
Fdsinozich
  • 29 Thanks
  • 76 posts
Posted September 17, 2015 - 08:49 AM
Again
#12 Fdsinozich OFFLINE
Fdsinozich
  • 29 Thanks
  • 76 posts
Posted September 17, 2015 - 11:40 PM
Again
#13 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1,179 Thanks
  • 697 posts
Posted September 19, 2015 - 08:45 PM
It looks like you have all the pieces there.It is pretty hard to explain in words how to put it together. Hopefully somebody on here has one they can take pictures of.
#14 KennyP ONLINE
  • 40,889 Thanks
  • 47,094 posts
Posted September 20, 2015 - 07:37 AM
Thanks
What brand is this GT1855?
#15 Fdsinozich OFFLINE
Fdsinozich
  • 29 Thanks
  • 76 posts
Posted September 24, 2015 - 07:15 AM
White Yard Boss
