So im looking at a JD 300
12 replies to this topic
#1 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted September 15, 2015 - 11:36 AM
As the title states im looking at trading my GT275 for the 300 what things should i look for on the 300 before i confirm the deal. It comes with a plow deck an tiller an extra tires weights an chains. he said it "uses" some oil but runs moves an cuts fine.
  • jd.rasentrac said thank you
#2 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,281 Thanks
  • 9,771 posts
Posted September 15, 2015 - 11:56 AM
Well, "using some oil" is about the most worrisome thing. Is it burning it or leaking it? If it is a cheap deal with the intent to rebuild the engine is one thing. Just go into it with your eyes open and ask a lot of questions.
  • backwoods said thank you
#3 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted September 15, 2015 - 12:17 PM
i was thinking a set of rings next summer if i get it anything else i should check other then the normal things
#4 Littledeere ONLINE
Littledeere
  • 1,650 Thanks
  • 1,483 posts
Posted September 15, 2015 - 05:20 PM
300's are good tractors just keep in mind there are not smooth tractors if all you plan to do is mow or plow some snow you may be happier with the 275
#5 Trav1s ONLINE
Trav1s
  • 3,285 Thanks
  • 4,351 posts
Posted September 15, 2015 - 06:15 PM
Things to watch for include:
- rubber motor mounts
- oil usage (plugged breather or bad rings or ???)
- belts
- rusty decks/bad bearings
They don't have the problems of the 312/314/317 and are very reliable machines.  As mentioned, the K341 is far from smooth.
#6 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,281 Thanks
  • 9,771 posts
Posted September 15, 2015 - 07:00 PM
. . .  As mentioned, the K341 is far from smooth.
But it's been very popular for a long time. And I would take it over those Kohler 2cyl. Series 1 things.
  • Trav1s and backwoods have said thanks
#7 Trav1s ONLINE
Trav1s
  • 3,285 Thanks
  • 4,351 posts
Posted September 15, 2015 - 08:39 PM
Yes... reliable and dependable it is.
#8 Oldford OFFLINE
Oldford
  • 1,134 Thanks
  • 786 posts
Posted September 16, 2015 - 02:21 AM
I have a 77, 300.  It is a good tractor, but 20 years older than your 275..?
Does the 275 have a kawa engine, how do they hold up?
300 should have dual hydro ports for a 4-way plow
My 300 plow dug in constantly til i welded a pipe on the bottom.
Traction was pretty bad until i added a weight box.  even with ww/chains.  tiller may help
Downside to those attachments maybe it was run hard all year long... for 40 years
Check the drive shaft couplers
Check the hydro fluid earlier ones had a dipstick, later a sight tube
Check the brakes, shoes are pretty expensive, good luck
  • backwoods and LilysDad have said thanks
#9 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted September 16, 2015 - 04:16 PM
The main reason for looking at it is the tiller an the 4 way snow plow an the option of having a 3piont/ sleeve hitch. An since im going to be doing a full restore on the cub 70 an it wont be used for plowing snow anymore
#10 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted September 17, 2015 - 10:47 AM
Well I'm going to look at the 300 Saturday an if I want to trade the guy said he would deliver it an after he looks mine over an wants it the deal is done.
#11 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted September 17, 2015 - 11:09 AM
heres the link to it  https://ithaca.craig...5202580573.html
#12 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,281 Thanks
  • 9,771 posts
Posted September 19, 2015 - 07:58 AM
That looks like it would clean up pretty good.
#13 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted September 19, 2015 - 08:06 PM
it cleaned up decent the rear fenders could use a repaint. Now i need to figure out how to mount the tiller arm i have no clue how it hooks up
