B&S Magnatron Conversion
18 replies to this topic
#16 webtechlin OFFLINE
webtechlin
  • 18 Thanks
  • 37 posts
Posted September 22, 2015 - 01:15 PM
Ok, that was another option I had.  Would you be able to send me a simple wiring diagram to do this?
Also, does it matter which coil I would buy?
Thanks
#17 MNGB ONLINE
MNGB
  • 2,438 Thanks
  • 1,510 posts
Posted September 22, 2015 - 03:26 PM
Hi web, I use a Wells LU800 12 V coil no need for ballast resistor if you can not find a lug on the ignition swith with 12 VDC when cranking then a separate ignition  switch is needed run a wire with +12 v to the + terminal of the coil run a wire from the - terminal of the coil to the points located on the lower engine block below the muffler / carb mount the coil on the engine.
#18 webtechlin OFFLINE
webtechlin
  • 18 Thanks
  • 37 posts
Posted September 22, 2015 - 03:48 PM
Awesome.
Thanks a lot...I'll give this a shot tonight and report back.
Appreciate the help!
#19 webtechlin OFFLINE
webtechlin
  • 18 Thanks
  • 37 posts
Posted September 25, 2015 - 09:16 PM
Just an update here.  Got the automotive coil installed, a new push button switch for the starter, and using the existing points.  Starts and runs really good.  This tractor has never started so easily.
Special thanks to MNGB, he really helped me through the process.
The wealth of knowledge on this site is amazing.
  • MNGB said thank you
