MF1414 Attachments
10 replies to this topic
#1 frenchy OFFLINE
frenchy
  • 29 Thanks
  • 163 posts
Posted April 11, 2011 - 07:57 PM
Hello all
I have Dynamark 14 or MF 1414 tractor. I picked it up used and want to put a blade and/or box scraper on it. I'm having a hard time finding attachments for it... should I just fabricate the attachments? I have some metal working knowledge, so I think i'm capable of it.... maybe :) Thoughts?
#2 frenchy OFFLINE
frenchy
  • 29 Thanks
  • 163 posts
Posted April 11, 2011 - 09:15 PM
here's a pic of the beast...
#3 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 177 Thanks
  • 1,009 posts
Posted April 11, 2011 - 09:25 PM
for the rear attachments you will need to buy a 3pt or make your own
#4 broken2 OFFLINE
broken2
  • 280 Thanks
  • 425 posts
Posted April 12, 2011 - 08:45 AM
Very nice tractor. What you have is the same as my amf1014, just different decals and the 1014 is orange&white. The Massey ferguson mf14 is the same except for the grill and hood and all the attachments will work on your tractor. I have found a parts mf14 with a deck, snowthrower and rear mounted tiller in Mass., no 3pt though. I don't think I'm going to get it, it's to far. If your interested I will try to find his #. The amf1414 is a different tractor. Gttalk member tractorgarden has posted info on the amf's, if you do a site search for 1014 or amf they should come up.
Edited by broken2, April 12, 2011 - 10:28 AM.
#5 NUTNDUN OFFLINE
  • 10,350 Thanks
Posted April 12, 2011 - 09:15 AM
I think it is great the different variations the tractors came in. I think it is great too that just in the past month or so now we have at least three of the AMF/Dynamark versions on the site :D
#6 tractorgarden OFFLINE
tractorgarden
    Junk Whisperer
  • 1,294 Thanks
  • 1,443 posts
Posted April 12, 2011 - 07:15 PM
frenchy, Wow, as the rest have said the AMF 1414 is a odd ball with not a lot in common with the rest of the amf built GT's. The parts for your tractor are the same as the Massey MF-14 and 16, and the AMF 1014. I would appreciate it if you could take a close up of your serial tag on the tractor. It would be great if you could also get the engine numbers, and maybe a good shot of the hydrostat pump under your seat. Thanks in advance Shawn
#7 NUTNDUN OFFLINE
  • 10,350 Thanks
Posted April 12, 2011 - 07:51 PM
Also don't be afraid to add it to the registry.
#8 frenchy OFFLINE
frenchy
  • 29 Thanks
  • 163 posts
Posted April 12, 2011 - 08:16 PM
Thanks for all the great info. I didn't realize what exact model it was. I was basing it off the other tractors I've seen on the forum and other sites. Here are the Serials and the hydraulic pump. The plan i have is to make a front and back blade out of a cut out section of a large air compressor tank and scrap steel. Sounds sketchy, but i'll make it work :)
  • tractorgarden said thank you
#9 frenchy OFFLINE
frenchy
  • 29 Thanks
  • 163 posts
Posted April 12, 2011 - 08:19 PM
that tractor model # is 5287. I just noticed you can't read it cause of the glare...Serial is 10325
#10 IamSherwood OFFLINE
  • 8,395 Thanks
Posted April 18, 2011 - 05:12 PM
[ATTACH=CONFIG]13098[/ATTACH][ATTACH=CONFIG]13099[/ATTACH][ATTACH=CONFIG]13100[/ATTACH]
Please keep us posted on your blade build.
#11 frenchy OFFLINE
frenchy
  • 29 Thanks
  • 163 posts
Posted April 20, 2011 - 01:02 PM
here you go: http://gardentractor...ilt-blade-5738/
