put together or not to put together
that is the question
22 replies to this topic
#1 stubbysteve OFFLINE
stubbysteve
  • 54 Thanks
  • 107 posts
Posted September 14, 2015 - 02:37 PM
Since I have some color now, I have another question. For those of you that have restored a db, do you put handles and brackets together first then paint so everything is the same or paint each part individual? I know it is kind of preference but if you paint individual then bolt everything you stand a chance of scratching paint.
  • Lauber1, chieffan and Thomasfews have said thanks
#2 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted September 14, 2015 - 04:39 PM
For a full restoration, if a full disassembly and rebuild is in order. Look at and photograph the pieces as they come off, so you can see what was painted from the factory assembled, and what was painted individually.
My self, since I don't do full resto's, If I have it off it gets painted, If I don't remove it gets painted as an assembly
  • Alc, chieffan, MGP59DB and 1 other said thanks
#3 chieffan ONLINE
  • 11,308 Thanks
  • 7,095 posts
Posted September 14, 2015 - 05:36 PM
I agree fully.  Unless your making a show piece and have protected wrenches I would do an much painting assembled as you can.  I don't do show pieces.  My equipment and tractor are working items.
  • Alc and Marty'70 have said thanks
#4 MGP59DB OFFLINE
MGP59DB
  • 1,737 Thanks
  • 795 posts
Posted September 14, 2015 - 06:03 PM
I agree with them as well . I painted the stuff I had apart on mine and if it wasn't apart it was painted assembled . I just went to the South Haven Mich. Flywheelers show this past weekend . I looked at a lot of tractors . 'Trailer Queens'  -They sure look nice ... too nice to take out in the dirt.
It all depends on what you are going for I guess .
I was lucky enough to see this tractor in person .
http://gardentractor...-june-2012-r109
1961 WH featured here June 2012 , This was a beautiful 'Show' piece .
I bought my tractor to use , but I also want it to look decent , so I am OK with 'Less than Show' quality . If I scratch it up ... no big deal . I didn't spend a fortune on how it looks and 3 automotive clear coats to make it shine.
In fact at this show it seemed that the ugliest tractors were the ones that the people were having the most fun with :D
But that doesn't mean it can't still look good .
Rustycong.jpg :smilewink:
  • Alc, VSTROM803 and HANKG have said thanks
#5 HANKG OFFLINE
HANKG
  • 6,590 Thanks
  • 3,527 posts
Its very important to let the paint dry really well not just a couple of days I will let it set for a week or two makes a big difference when bolting things back together
  • Alc and MGP59DB have said thanks
#6 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted September 14, 2015 - 06:09 PM
when doing a DB, keep in mind that the parts or some complete assemblies were dip painted, while being wire tied together. they isn't any way to duplicate that in the field. I ussally paint all the parts, then assemble, then repaint things like the handle hookup parts and other things that get rough treatment. Most of the look of a DB is the hood, so spend the most time getting that part right, and then the wheels.
#7 jabelman OFFLINE
jabelman
  • 2,241 Thanks
  • 1,605 posts
Posted September 14, 2015 - 07:04 PM
The main question is what is the use going to be. I do full restorations taking them all apart and i will be honest they are very limited use we drive them around yard with the kids and have fun with them. for the working machines they are maintained and if parts come off they get cleaned and put back on.
#8 stubbysteve OFFLINE
stubbysteve
  • 54 Thanks
  • 107 posts
Posted September 14, 2015 - 10:10 PM
Well this one more of a show piece. But since my original engine is in dire need of repair, I have to go with a later model engine. So it is a total rebuild. I did pull the tranny apart. Cleaned put back together. I have everything primed.just was wondering if I should put parts togrther on the machine then paint. Cause it looked as if it was done that way from factory. As in all bolts and everything. And it will be used for shows and hauling kids around and the such.
#9 stubbysteve OFFLINE
stubbysteve
  • 54 Thanks
  • 107 posts
Posted September 17, 2015 - 06:59 AM
I had to go through all 4 dbs to get a set of wheels that would even possibly hold air. I had to take one off the 48 and one off the 54. The others were literaly rotted through. One of the ones I have are pitted pretty bad. Has any one heard of bondoing a wheel before?
#10 jabelman OFFLINE
jabelman
  • 2,241 Thanks
  • 1,605 posts
Posted September 17, 2015 - 08:27 AM
No but I brush rusteluem on the inside of the rims and put tubes in them. I don't reload the tires either since they are not for use anymore.
Edited by jabelman, September 17, 2015 - 08:27 AM.
  • Lauber1 said thank you
#11 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted September 17, 2015 - 12:27 PM
shouldn't have been an issue as all the older db rims were tubetype, they weren't made for modern tires.
#12 stubbysteve OFFLINE
stubbysteve
  • 54 Thanks
  • 107 posts
Posted September 17, 2015 - 03:30 PM
Just found out I have a hole in onr of the rims. About half the size of a pencil. Do you think it can be welded and work or is it shot?
#13 jabelman OFFLINE
jabelman
  • 2,241 Thanks
  • 1,605 posts
Posted September 17, 2015 - 05:43 PM
Post a pic. Shouldn't matter with a tube
  • stubbysteve said thank you
#14 stubbysteve OFFLINE
stubbysteve
  • 54 Thanks
  • 107 posts
Posted September 17, 2015 - 08:39 PM
I will post a picture tomorrow. Thanks
#15 IWLBCNU OFFLINE
IWLBCNU
  • 123 Thanks
  • 160 posts
Posted September 18, 2015 - 10:50 AM
When I did my 'show' tractor, it was my third DB and I had very few parts, and hadn't started collecting yet. The rims I had to use were very rough. I used All-Metal which is a type of bondo and smoothed all the pits and rebuilt the valve stem holes. They have held up for 9 years now with no problems. On a John Deere rim I have cut out a section of rim from another and butt welded it back into the better rim and still need to drill the hole, but was able to make it smooth with no bondo.
  • Alc and pigsitter have said thanks
