3 pt disc problem
8 replies to this topic
#1 lbyeah OFFLINE
lbyeah
  • 6 posts
Posted April 11, 2011 - 06:11 PM
my disc setup is drivin me nuts i cant get it to engage evenly it want to ride up on one side i have adjust till my knuckles bleed any ideas
#2 MH81 OFFLINE
Posted April 11, 2011 - 06:18 PM
Is this a brinly or 3 pt setup? If it's 3point, the adjustment should be pretty easy, I'd it's brinly, we may have more problems.
#3 lbyeah OFFLINE
lbyeah
  • 6 posts
Posted April 11, 2011 - 06:25 PM
its a sears factory 3pt
#4 lbyeah OFFLINE
lbyeah
  • 6 posts
Posted April 11, 2011 - 06:26 PM
i have made all adjustmust i m beginning to think there is to much slop in the arms
#5 coldone OFFLINE
coldone
  • 1,651 Thanks
  • 1,679 posts
Posted April 11, 2011 - 07:45 PM
A pic of the setup might help us figure out whats happening.
#6 MH81 OFFLINE
Posted April 11, 2011 - 08:02 PM
If you adjust everything so the discs are level with the ground, it should be just fine. If you have the attack angle to hard, it'll tend to raise up in the back. I found the best was about 15-20 degrees forward on the outside, if any tilt (front to back) is needed, maybe a little bit high in the front to counter for how the back may lift in use.
#7 lbyeah OFFLINE
lbyeah
  • 6 posts
Posted April 11, 2011 - 08:06 PM
i have change the pitch angle of the disc no help i have adjusted all level no help i have gone crazy i think one side will always work the other raises up sorry cant get pics to upload from my phone
#8 MH81 OFFLINE
Posted April 11, 2011 - 08:23 PM
I guess without seeing it, the best I can tell you is adjust the side that is not digging lower and sink the back a little. Also, strap a cement block to the top as a test, then see if it helps. Sometimes guys have just had to weigh them down a little.
#9 Deck_Drive OFFLINE
Deck_Drive
    collector of sears
  • 97 Thanks
  • 348 posts
Posted April 11, 2011 - 09:40 PM
does the disc just roll? it might be that they arnt angled correctly.
