fluid in the tires?
5 replies to this topic
#1 pumpkintoter OFFLINE
pumpkintoter
  • 11 Thanks
  • 181 posts
Posted April 11, 2011 - 05:22 PM
i recently purchased a 316 and the guy i got it off of said that the tires were fluid filled heres the question one of them looks a little low how do i fill it? i know its a noob question but im not sure if i just air it up or if there is something special i need to do.
#2 olcowhand OFFLINE
  • 42,885 Thanks
  • 31,934 posts
Posted April 11, 2011 - 05:32 PM
Likely the fluid is still all in there. They should only be filled 70% or so with fluid, the rest being air space. Simply air them up.
#3 poncho62 OFFLINE
poncho62
  • 2,102 Thanks
  • 1,775 posts
Just add air...make sure the valve is at the top.
You might want to take the wheels off and weigh them, just so you will know how full of fluid they are.......Might want to ask the previous owner what he filled them with too.
#4 pumpkintoter OFFLINE
pumpkintoter
  • 11 Thanks
  • 181 posts
Posted April 11, 2011 - 05:57 PM
great thanks fellas will do..
#5 middleageddeere OFFLINE
middleageddeere
    Tacos!
  • 243 Thanks
  • 1,082 posts
Posted April 11, 2011 - 08:20 PM
Yeah, you can do a little research on what different guys fill em with and why once you find out what they are filled with. If you do find out let us know I am sure we can help.
#6 tex tractor jack OFFLINE
tex tractor jack
  • 42 Thanks
  • 86 posts
Posted April 11, 2011 - 08:27 PM
Just make sure the valve stem on the wheel is turned to the top of the rotation. This will keep back flow out of your air hose and also the tire gauge when you check the pressure.
good luck,
Jack
