Bolens fuel sender unit
4 replies to this topic
#1 backyardtinker OFFLINE
backyardtinker
  • 249 Thanks
  • 182 posts
Posted September 13, 2015 - 10:17 AM
Has anyone used one of these as a replacement for the fuel tank sending unit on any Bolens machines? Specifically, I want it for my 5120H Duratrac GT2000. Unless  anyone knows if I can get an O.E.M or equivalent. These look nearly identical but I don't know the dimensions. Mine has a five bolt pattern that has a spread of approx: 2" on center. I figure the float rod can be shortened to fit the application.
http://www.ebay.com/...r-/291472912533
#2 boyscout862 OFFLINE
  • 13,693 Thanks
  • 9,476 posts
Posted September 13, 2015 - 01:32 PM
Check with our sponsors. Good Luck, Rick
  • backyardtinker said thank you
#3 Bolens 1000 ONLINE
  • 15,564 Thanks
  • 18,321 posts
Posted September 13, 2015 - 06:20 PM
Do you have the serial number, two styles were used depending on the serial number
#4 backyardtinker OFFLINE
backyardtinker
  • 249 Thanks
  • 182 posts
Posted September 19, 2015 - 07:14 AM
The S/N is 0200766. Thanks much!
#5 Bolens 1000 ONLINE
  • 15,564 Thanks
  • 18,321 posts
Posted September 19, 2015 - 07:56 AM
Sent you a PM
