Coil for a '59' DB Suburban
11 replies to this topic
#1 MGP59DB OFFLINE
MGP59DB
  • 1,678 Thanks
  • 766 posts
Posted September 13, 2015 - 08:30 AM
Hi - I am hoping to find a coil for my Uncles Machine . I know they are hard to find but he is at a standstill on this until something can be done . He went thru the electrical system and still is not getting much spark .
So - can anyone help me find this . He has the B&S 5.75 143302 motor .
Like this one .
He did so much to help me with my tractor , I really need to find this for him .
#2 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted September 13, 2015 - 08:50 AM
Take the numbers off the engine along with the coil to any reputable small engine shop and they should be able to dig one up. That can also be converted to a newer style Briggs electronic coil, that's what I did with mine, works great. Good luck.
  • Alc, boyscout862 and MGP59DB have said thanks
#3 jabelman OFFLINE
jabelman
  • 2,231 Thanks
  • 1,596 posts
Posted September 13, 2015 - 09:24 AM
As long as u have the armature you can get a coil kit. The guy on here sells old path equipment.
A new complete briggs coil is big money.
It's a little complicated to convert a 3 leg coil to the newer style. These engines are simple enough
  • MGP59DB said thank you
#4 MGP59DB OFFLINE
MGP59DB
  • 1,678 Thanks
  • 766 posts
Posted September 13, 2015 - 11:09 AM
What does the coil kit consist of ? He has the old one .
#5 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted September 13, 2015 - 11:29 AM
I payed the same money for my electronic coil setup as I would have payed for a replacement, not including the points. 24 bucks used off of a lawnmower.
I don't see where you are coming from??
The conversion was a matter of setting the coil gap and bolting it on!!!
#6 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted September 13, 2015 - 11:35 AM
Sorry, double post
Go Pack Go!!!!
Edited by stiemmy, September 13, 2015 - 11:49 AM.
#7 VSTROM803 OFFLINE
VSTROM803
  • 373 Thanks
  • 338 posts
Posted September 13, 2015 - 07:05 PM
Here's what I got for mine.
http://www.ebay.com/...=item3ce84b47fb
  • Bruce Dorsi and MGP59DB have said thanks
#8 MGP59DB OFFLINE
MGP59DB
  • 1,678 Thanks
  • 766 posts
Posted September 13, 2015 - 08:52 PM
/\ So that replaces the wire core of the original using the existing armature and magnet? How hard is it to put in?  I just don't know much about these . But I looked in the book and it has the right replacement # for the part in the list - 296834
My Uncle is old school and I know he wants it with the points rather than converting it over.
Edited by MGP59DB, September 13, 2015 - 08:54 PM.
#9 VSTROM803 OFFLINE
VSTROM803
  • 373 Thanks
  • 338 posts
Posted September 14, 2015 - 04:04 AM
It's pretty easy to install. Just remove the clip and slide the coil off the armature. Install the new one with the supplied clip and your in business. You still use points and condensor.
#10 MGP59DB OFFLINE
MGP59DB
  • 1,678 Thanks
  • 766 posts
Posted March 20, 2016 - 12:49 PM
Bump - This is a continuing conversation - Now not with a 59DB but with My Model 36 .
The machine has the same motor same ignition set-up . Well... yesterday we were going thru the ignition and were only getting a weak intermittent tickle .
Replaced the plug wire , tried 2 different condensors , gaps good , everything seems good , but now there is absolutely not even tickles.
I have ordered the replacement coil parts from above and will replace them .
I am wondering if anyone else may have some idea's as to a possible reason there is just nothing going on with this thing?
I wonder if maybe this is why there is so little wear on the machine , an ongoing spark issue.
Hopefully the coil parts will fix it.
And I was so confident it was just a minor thing.
#11 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted March 20, 2016 - 07:30 PM
it was a weak link in these engines, that's why people yrs later pulled off the flywheel and coil and replace them with a magnetron system. You can find what you need on any 8hp IC briggs.
#12 MH81 OFFLINE
Posted March 20, 2016 - 09:45 PM
My uncle would take every one of these engines he got and replace the system with a coil.
He found a (?suzuki?) mini bike coil would fin in the housing and not be too ugly.
