Help identify this tractor
8 replies to this topic
#1 Bigpapad OFFLINE
Bigpapad
  • 5 Thanks
  • 8 posts
Posted September 11, 2015 - 05:06 PM
I need help identifying this tractor I know it is a bolens just don't know what kind it has a brings PB engine. As you can see it is going to be repaired. It was my father's. I also need to know how to find out when it was built.IMG_20150911_170011.jpg IMG_20150911_170011.jpg
#2 DougT OFFLINE
DougT
    Dog Approved
  • 6,928 Thanks
  • 4,996 posts
Posted September 11, 2015 - 05:27 PM
For some reason the pics won't expand but it looks like a Bolens DJ. What's the serial number on the PB.  That wil get us close on the year.
  • Alc, Auburn David and Bigpapad have said thanks
#3 Bigpapad OFFLINE
Bigpapad
  • 5 Thanks
  • 8 posts
Posted September 11, 2015 - 05:59 PM
The serial number starts with 16 and looks like it could be four of five digits can't read anything else.
#4 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted September 11, 2015 - 06:45 PM
Nope..wont expand for me either.
#5 gunstuff1000 OFFLINE
gunstuff1000
  • 948 Thanks
  • 564 posts
Posted September 11, 2015 - 08:28 PM
So hard to tell the picture is a little fuzzy Look to see if he wheels are cast iron or stamped steel. If they are cast u probably have a DJ if stamped steel then a model D or course someone could have swapped wheels out. Another tell tell sign is the drive chains are they roller chain or block chain Roller chain then DJ Hope the info helps u out
  • Alc and Bigpapad have said thanks
#6 Bigpapad OFFLINE
Bigpapad
  • 5 Thanks
  • 8 posts
Posted September 11, 2015 - 09:19 PM
Thanks for your help . I am not planning on using it in the dirt, I have cultivates for it but the other side of the picture the wheel broke off at the base . I have someone making a cast for it.They are cast wheels.IMG_20150911_165951.jpg
  • LPBolens said thank you
#7 DougT OFFLINE
DougT
    Dog Approved
  • 6,928 Thanks
  • 4,996 posts
Posted September 11, 2015 - 10:27 PM
Is the number stamped on the tag or the block? If it was a 4 digit number with 16XX it would be on the block. Engine number 16,000 was the last PB eng built in 26. Jan and Feb 27 had engines produced in the 16,000 range.
#8 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,773 Thanks
  • 4,265 posts
Posted September 12, 2015 - 05:39 AM
welcome to GTt, bigpapade
#9 Bigpapad OFFLINE
Bigpapad
  • 5 Thanks
  • 8 posts
Posted September 12, 2015 - 08:16 PM
It has a tag so it must be a 26 or 27 . I will post new pics with cultivaters when it gets fixed.
