cross over for points assembly
4 replies to this topic
#1 stubbysteve OFFLINE
stubbysteve
  • 54 Thanks
  • 107 posts
Posted September 10, 2015 - 04:52 PM
Is there any cross over numbers for the contiental engines? The oem number is aa7m-2990 and condencer is aa7m-2980. Need that number also. Thanks
#2 boyscout862 ONLINE
  • 11,827 Thanks
  • 8,673 posts
Posted September 10, 2015 - 04:56 PM
Check with our sponsors. OldPaths Equipment seems to have alot of the old books. Good Luck, Rick
#3 dblover OFFLINE
dblover
  • 267 Thanks
  • 160 posts
Posted September 10, 2015 - 05:24 PM
Search feature is your friend:
If your engine tag number ended in A use wico points and condenser # point and condenser set part # X-7572. Now if your AU7 has a B after the 6 numbers 127-100B or 127101B you used Phelon parts the phelon part numbers are conndenser #FG-458G Points FG-626
Next came Au7 127102 Au8127300 and Au85s127400 and 127450 these engines all used points no longer under the flywheel all used the same part so if you have the plastic governor cap no matter what model they all used the same same points and condensor, the part number is this points AA7M-2990 condenser AA7M-2980.
http://gardentractor...nental-engines/
Then Google this info to find Ebay . . .points   http://www.ebay.com/...121683789564
$16
Edited by dblover, September 10, 2015 - 05:28 PM.
  • Alc, TomLGT195 and Pats have said thanks
#4 dblover OFFLINE
dblover
  • 267 Thanks
  • 160 posts
Posted September 10, 2015 - 05:38 PM
Or maybe . . . these points
CONTINENTAL MOTORS CORP. MODELS AA-7,AA-7B,AA-8,AC-5,AC-6,AD-7,AD-8,AU7,AU7B,AU-7R,AU-8,AW-7,AW-7B,AW-8: 127:100,127:101 , 127:102 ,     All these models must have Mag # FW-2158
http://www.ebay.com/...=item1ea39541d6
CONTACT POINT SET CONTINENTAL LAUSON JACOBSON WICO STRUNK SPORT KING X7572 NIB
$T2eC16Z,%21zgFIdBiytn%21BSTOhvjdB%21~~6
#5 stubbysteve OFFLINE
stubbysteve
  • 54 Thanks
  • 107 posts
Posted September 10, 2015 - 07:13 PM
None look the same. My condencer has wire. Mine is au85.
