And suddenly....they leaked
12 replies to this topic
#1 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,625 Thanks
  • 1,311 posts
Posted September 10, 2015 - 12:47 PM
Most of our old engines will leak without fuel shutoffs. Most came with factory fuel shutoffs (some in inconvenient locations). Most of the time after I go thru the carbs they don't leak or leak very little for a long while....Then it happens,suddenly,usually very inconveniently. Last week I had 3 good running,normally non leakers decide to leak all in the same week. Including a Honda that I hadn't had to shut the fuel off on in two years. One decided it would even leak with the fuel shutoff turned off. Guess I need to buy some new shutoffs.
Edited by rustyoldjunk, September 10, 2015 - 12:49 PM.
  • MH81, boyscout862, TomLGT195 and 3 others have said thanks
#2 Bolens 1000 OFFLINE
  • 14,987 Thanks
  • 18,140 posts
Posted September 10, 2015 - 12:53 PM
Yep we've all been there
The engines of the 70's and earlier almost always had a note in the manual to shut off the fuel when not in use. I always shut off my fuel valve when the engine is running then let it idle for a minute or two to get the gas out of the fuel line then turn off the machine which guarantees it will not leak when you store it in the garage.
Once the Fuel solenoids came into existence the leaking problems were stopped :D
  • rustyoldjunk, Alc, boyscout862 and 1 other said thanks
#3 HANKG ONLINE
HANKG
  • 6,324 Thanks
  • 3,427 posts
Posted September 10, 2015 - 01:22 PM
Just had the same problem Boyscout helped me out with a napa part number I had trouble finding 7-02351 universal shut off valve.
  • rustyoldjunk said thank you
#4 rustyoldjunk OFFLINE
rustyoldjunk
  • 2,625 Thanks
  • 1,311 posts
Posted September 10, 2015 - 01:31 PM
I'm used to it after 20 plus years of playing with old engines but I found it interesting that 3 all in the same week kicked off a leaking party after no new issues for months....About the fuel shut off relays....I hate them... :poke:
  • propane1 said thank you
#5 bryan 110 OFFLINE
bryan 110
  • 221 Thanks
  • 290 posts
Posted September 10, 2015 - 03:31 PM
I've never had any of mine leak. Am I lucky?
#6 JBRamsey ONLINE
JBRamsey
  • 1,474 Thanks
  • 841 posts
Posted September 10, 2015 - 06:42 PM
You probably just jinxed yourself.
#7 gopher OFFLINE
gopher
  • 764 Thanks
  • 758 posts
Posted September 10, 2015 - 07:40 PM
By chance were tanks topped off? That heat wave last week probably expanded the gas pretty much. Happens all the time diesel tanks. Just a thought.
#8 rustyoldjunk OFFLINE
rustyoldjunk
  • 2,625 Thanks
  • 1,311 posts
Posted September 10, 2015 - 09:32 PM
And now he waits for the other shoe to fall.....
Never happens with the semi's and I checked the injectors to be sure.... :poke:  It might have been an issue but at least one still leaking and it's cooler. Guess I should do something about that instead of watching the puddle get bigger. :flipping_flapjacks:
#9 BTS OFFLINE
BTS
    Make Stuff Up
  • 4,269 Thanks
  • 2,462 posts
Posted September 10, 2015 - 11:29 PM
My bolens HT23 started leaking out the carb a few days ago, I took it apart and rebent the float. It's all working fine now.
  • rustyoldjunk and Alc have said thanks
#10 bryan 110 OFFLINE
bryan 110
  • 221 Thanks
  • 290 posts
Posted September 11, 2015 - 07:30 PM
Lol ya I should look at them now they all might be leaking. Lol I have a problem that I don't use them enough and the battery dies
#11 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted September 12, 2015 - 05:20 AM
I don't  like the fuel solenoid idea that much , the Toro 1 plays up all the time , takes ages to start some times
#12 KennyP ONLINE
  • 38,490 Thanks
  • 45,978 posts
Posted September 12, 2015 - 06:14 AM
Once the solenoids quit working, they allow the crankcase to fill full of fuel!
  • rustyoldjunk and holdenboy1960 have said thanks
#13 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted September 12, 2015 - 06:25 AM
now that sounds like trouble  i don't want, but mine is really slow to open i discovered when i took it out & tried it
but the machine sat in a garage for 2 yrs with stale fuel in it ;
it was a hell's own job cleaning all the gunk out of every thing when i 1st got it
