I need a part pattern
37 replies to this topic
#1 wvbuzzmaster OFFLINE
  • 4,663 Thanks
  • 7,409 posts
Posted September 08, 2015 - 09:27 PM
I need help. I am looking for a pattern to make a linkage for my New Holland S-14 rear rockshaft. I acquired the rear rockshaft and the "flipper" that helps to jam the front or rear lift so that the other operates. What I need still is the linkage that operates this "flipper" and slips thru the slot in the frame. I can make this out of 3/8" round stock, and it has some springs on it, which I can make several assumptions to build this linkage, but if I had a picture (top view) and a couple basic dimensions to scale the picture as a pattern, I could make one fairly close to OEM. In fact, make two... I have a friend that will need one too if I help him make a rear rockshaft using mine as a pattern for his. If anyone can help with this it would be great. I have a goal I might not make of getting this to a plow day (Sept 26)... But I need the lift finished.
PS: Ariens is the same setup.
Edited by wvbuzzmaster, September 08, 2015 - 09:29 PM.
#2 shorty ONLINE
shorty
  • 4,572 Thanks
  • 4,700 posts
Posted September 09, 2015 - 04:36 AM
I can get it tonite after work. I have a tractor opened up right now, it won't be hard to get a pic.
  • MH81, Alc, wvbuzzmaster and 1 other said thanks
#3 shorty ONLINE
shorty
  • 4,572 Thanks
  • 4,700 posts
Posted September 09, 2015 - 04:02 PM
This is from my Ariens S-16. Shows the springs on either side of the flipper tab.
#4 shorty ONLINE
shorty
  • 4,572 Thanks
  • 4,700 posts
Posted September 09, 2015 - 04:27 PM
#5 wvbuzzmaster OFFLINE
  • 4,663 Thanks
  • 7,409 posts
Posted September 09, 2015 - 04:34 PM
Well that will be fun to make...
#6 shorty ONLINE
shorty
  • 4,572 Thanks
  • 4,700 posts
Posted September 09, 2015 - 04:52 PM
Shows front side with the drop and the little plate inside the frame. And another flipped pic.
#7 shorty ONLINE
shorty
  • 4,572 Thanks
  • 4,700 posts
Posted September 09, 2015 - 04:53 PM
Those little offsets will be interesting.
#8 wvbuzzmaster OFFLINE
  • 4,663 Thanks
  • 7,409 posts
Posted September 09, 2015 - 04:59 PM
Very interesting... Might need to invent something or wait out a real one...
  • shorty said thank you
#9 KennyP ONLINE
  • 34,233 Thanks
  • 43,348 posts
Posted September 10, 2015 - 07:52 AM
Aw come, Casey! You can do it! Better get 30' of that rod to start with!
  • wvbuzzmaster, Delmar, shorty and 1 other said thanks
#10 wvbuzzmaster OFFLINE
  • 4,663 Thanks
  • 7,409 posts
Posted September 10, 2015 - 11:00 AM
Thanks for the confidence Kenny. I know i can make it in a day if i just had a day i could devote to it...
  • KennyP and shorty have said thanks
#11 MH81 ONLINE
  • 29,911 Thanks
  • 29,738 posts
Posted September 10, 2015 - 11:15 AM
C'mon Casey!
With as smart a fella as you, your back ground, and your Dad to help.... That's a three hour project. Including installation.
  • wvbuzzmaster, KennyP and shorty have said thanks
#12 Wm McNett OFFLINE
Wm McNett
  • 121 Thanks
  • 165 posts
Posted September 11, 2015 - 11:02 AM
If it helps
http://www.jackssmal...ariens/7644/296
  • MH81, wvbuzzmaster and KennyP have said thanks
#13 MH81 ONLINE
  • 29,911 Thanks
  • 29,738 posts
Posted September 11, 2015 - 11:07 AM
If it helps
Geez, for 35, it's almost not worth the frustration.
You'd still need the springs, washers, hairpins, etc... But the rod itself would be correct.
#14 wvbuzzmaster OFFLINE
  • 4,663 Thanks
  • 7,409 posts
Posted September 11, 2015 - 04:49 PM
Yay, i been trying to find that link again for at least a week. Ya, 35 is worth it
#15 olcowhand ONLINE
  • 38,038 Thanks
  • 30,448 posts
Posted September 11, 2015 - 06:20 PM
Where's your sense of challenge?  Just blow the diagram pic up, then get out the torch.  Do keep the torch away from the diagram though!  Oh well......order it!  :smilewink:
