Bolens RAM 57 to 59 compatibility?
3 replies to this topic
#1 Manfjourde OFFLINE
Manfjourde
  • 119 Thanks
  • 180 posts
Posted September 07, 2015 - 08:48 PM
Do you think I can get a cultivator and plow from a 57 RAM to work on my 59? Would modifying a bracket/hitch be worth it or too much effort.
Also, would a 57 blade and bracket work on my 59?
The blade with the gray tiller is supposedly from a 59 and the other a 57. They look the same to me making me think the 57 would work on the 59. These pics aren't mine, from members on the forum.
#2 boyscout862 ONLINE
  • 13,559 Thanks
  • 9,433 posts
Posted September 08, 2015 - 06:49 AM
I believe that there is a Bolens Attachment Chart in our Manuals Section. It may help with your question.
  Attached File  Bolens Tractor Attachments Guide.pdf   3.63MB   7 downloads  Good Luck, Rick
  • Alc and CanadianHobbyFarmer have said thanks
#3 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,988 Thanks
  • 2,479 posts
Posted September 08, 2015 - 08:25 AM
The Attachment Interchange for the Ride-A-Matics can be found here:
http://gardentractor...erchangeabiity/
The 1956-57 (models 20HD & 21HD) & 1958 ( model 220) tractors had a different style rear hitch than later model tractors, so some of the rear attachments would require modification or a later #23839 drawbar.
Pics of the #23839 drawbar can be found in the manuals for the #23122 cultivator, or #23256 disc harrow.  http://gardentractor...tor-attachment/
http://gardentractor...57-disc-harrow/
There were two model snow plows for the R-A-M's (HD531 and 21531).  Either snow plow should be able to mount to your 1959 tractor by using later mounting brackets.
If you have not yet found them, there is a whole section of the manuals forum for Ride-A-Matic tractors and attachments at:
http://gardentractor...s-ride-a-matic/
  • boyscout862 and Manfjourde have said thanks
#4 Manfjourde OFFLINE
Manfjourde
  • 119 Thanks
  • 180 posts
Posted October 24, 2015 - 05:45 PM
So just to make sure the blade and mount with the patina, sitting outside would work on a 59 RAM? Want to be exactly sure before I buy.
