EGT200 Plowing the garden
12 replies to this topic
#1 DH1 ONLINE
DH1
    Electric Tractors
  • 5,415 Thanks
  • 5,616 posts
Posted September 07, 2015 - 03:03 PM
Well I've asked the question before and today I found out for myself.
Can a GE tractor pull the plow in the garden?
Yes it can. :dancingbanana:  :dancingbanana:  :dancingbanana:
Today I took my EGT200, similar to the general electric E20, put a Brinly 10" plow on it with a sleeve hitch and tried it out in the garden.
I spent a lot of time testing, adjusting, trying different things, setups and got it working pretty good.
It pulls the plow in L (2nd gear) best, and it has the power to pull it in D (3rd gear).
GE recommends L or LL for plowing. Transmision is a Peerless 2300, 4sp.
Tractor still has some issues to deal with but when it's working it can do it.
One thing I notice is traction, never spun the tires at all, tractor has factory turf's on it with NO extra weight added.
Today was a test and tune day, I didn't take any video's as I was having trouble at the start getting it to work, multiple problems, about 1/2 way through I got it figured out and it seems to work good. I have never done this with a GE tractor so I have nothing to compare it to, only what I see on the internet.
I got to take this to a plowday sometime.
Factory Sleeve hitch with the Manual lift and a 10" Brinly plow
  • olcowhand, daytime dave, Alc and 11 others have said thanks
#2 propane1 ONLINE
propane1
  • 9,435 Thanks
  • 4,379 posts
Posted September 07, 2015 - 03:14 PM
About how deep were you plowing ?  Looks great, you need a set of disks now.   Noel
  • DH1 and boyscout862 have said thanks
#3 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted September 07, 2015 - 03:18 PM
Doug, how do you reach the lift handle from the seat?
Nice furrows.
  • DH1 said thank you
#4 DH1 ONLINE
DH1
    Electric Tractors
  • 5,415 Thanks
  • 5,616 posts
Posted September 07, 2015 - 03:36 PM
About  4" to 5" , the last furrow is way to deep, tractor leaned over too much on that pass.
Nice furrows.
The lift handle is a problem, they modified the GE lift on the front mount tractors to fit the New Idea mid mount tractors and in doing so they made it harder to pull the handle up when the plow is on, also it does stick out back far but you can still reach it from the seat.
  • Alc, wvbuzzmaster and propane1 have said thanks
#5 Little Irish Men ONLINE
Little Irish Men
  • 840 Thanks
  • 475 posts
Posted September 07, 2015 - 03:53 PM
You make it look so easy , i wish i could have mine look like that so good . nice job .
Patrick.
#6 olcowhand ONLINE
  • 42,896 Thanks
  • 31,939 posts
Posted September 07, 2015 - 04:22 PM
Once you get it all dialed in, you oughta either build a winch lift or use a boat's hydraulic trim pump to build a power lift.  Looks like it's doing a super good job.
#7 DH1 ONLINE
DH1
    Electric Tractors
  • 5,415 Thanks
  • 5,616 posts
Posted September 07, 2015 - 04:25 PM
Thanks Dan you know as old as it is with mostly original parts, electrical parts, all the connections and points where power can be lost.
This thing really truly works.
I'd love to try a brand new one.
#8 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted September 07, 2015 - 05:47 PM
Just be careful about that Doug. Just because you can reach a lift lever from the seat doesn't mean it is ergonomic enough to prevent a back injury... Trust me, a manual lift tiller on a 1974 Gilson 16 HP gear drive tractor screwed up my upper back / shoulder several years ago. Can still feel that 'twinge' at times on long drives.
#9 KC9KAS ONLINE
KC9KAS
  • 5,461 Thanks
  • 4,722 posts
Posted September 07, 2015 - 06:06 PM
Good looking plow job.
#10 Traill95 OFFLINE
Traill95
    Traill95
  • 1,858 Thanks
  • 1,020 posts
Posted September 07, 2015 - 06:13 PM
Nice. I am always looking for an E20 Elec-Trak. I don't know if the E14 will pull a plow or not. Guess I am gonna have to find a plow and give it a try. Thanks for the pics.
#11 TomLGT195 OFFLINE
TomLGT195
  • 4,046 Thanks
  • 2,899 posts
Posted September 08, 2015 - 01:32 PM
I'd like to see that plowing.
#12 DH1 ONLINE
DH1
    Electric Tractors
  • 5,415 Thanks
  • 5,616 posts
Posted November 08, 2015 - 03:21 PM
Well today was a nice day for a Nov 8th and I thought I'd try again.
Same setup as before Brinly 10" , turf tires with no extra weight and NO traction problems at all, NO tire slippage.
The Power use meter was in the high green to top of the red zone, sometimes above the top, tractor was run in L or 2nd gear on a peerless 4sp.
Plowed all this in 1/2hr non stop.
https://www.youtube....h?v=ArnncPRsB_o
  • olcowhand, daytime dave, Alc and 3 others have said thanks
#13 daytime dave ONLINE
  • 4,963 Thanks
  • 6,596 posts
Posted November 08, 2015 - 05:50 PM
Doug, I can't believe I missed this one the first time around.
Great job.  I liked the video.  It sure does a nice amount of work.  I replaced the usage gauge on my GE, only to find the new one didn't work either.
  • DH1 and sacsr have said thanks
