4 Wheel Wagon
4 replies to this topic
#1 KC9KAS OFFLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted September 07, 2015 - 01:28 PM
Like I need more projects! My ADHD keeps me bouncing around the way it is.
Take a look at what I am working on now. Got a long way to go!
Edited by KC9KAS, September 07, 2015 - 01:33 PM.
  • Gtractor, Alc, KennyP and 4 others have said thanks
#2 twostacks OFFLINE
twostacks
  • 479 Thanks
  • 438 posts
Posted September 07, 2015 - 02:53 PM
Looks like it will be a pretty hefty wagon.
#3 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted September 07, 2015 - 03:14 PM
   what did you do use, a front axle on the rear and just pin the steering in place ?  Looking good.  what are you dong for a deck ?
#4 KennyP ONLINE
  • 38,420 Thanks
  • 45,955 posts
Posted September 07, 2015 - 05:38 PM
Might want to support that in the middle as it could fold!
  • Gtractor said thank you
#5 KC9KAS OFFLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted September 07, 2015 - 05:59 PM
Used 2 Wheel Horse frames cut off at the rear trans mount.
Welded together with a piece of angle iron on each side as reinforcement.
The rear axle will have spindles welded straight and the center pivot welded so it doesn't pivot with the frame. The front turning mechanism will probably be the hardest part to figure out. I will pivot and turn.
I plan on bolting a treated 4 X 4 on each side of the frame and build off of that.
  • limebuzz and Alc have said thanks
