Category 0 three point adapter
20 replies to this topic
#1 wvbuzzmaster OFFLINE
  • 4,496 Thanks
  • 7,345 posts
Posted September 06, 2015 - 09:26 PM
Need a little help here. I will have a three point Category 0 hitch on my New Holland soon (this month) and the first thing I need to build is a Cat 0 universal hitch (sleeve hitch and trailer ball) and I have no implements to base this off of. I do know it will need 20" spacing but not sure where the 20" starts. I will be using a piece of 2"x2"x3/8" thick angle iron and welding 5/8" bar stock on the internal corner of the angle to keep this cheap and sturdy. So based on this I may need dimensions to help me, including how high above the pins is the top link attachment point... Any help appreciated.
#2 David Brown OFFLINE
David Brown
  • 4,403 Thanks
  • 2,385 posts
Posted September 06, 2015 - 09:43 PM
Casey, I assume you are talking about what's commonly called an A frame or basically a drawbar with upper arms that connect to the third point?  If so, I can get you all the dimensions you need tomorrow.
  • wvbuzzmaster said thank you
#3 wvbuzzmaster OFFLINE
  • 4,496 Thanks
  • 7,345 posts
Posted September 06, 2015 - 09:47 PM
Sounds like exactly what I am talking about (as if I know what I am talking about lol). I appreciate it, Jeff. Dimension wise I probably don't need many (famous last words lol).
Edited by wvbuzzmaster, September 06, 2015 - 09:48 PM.
#4 David Brown OFFLINE
David Brown
  • 4,403 Thanks
  • 2,385 posts
Posted September 06, 2015 - 09:50 PM
What I was trying to explain shows up in this picture.  This what you need?
#5 wvbuzzmaster OFFLINE
  • 4,496 Thanks
  • 7,345 posts
Posted September 06, 2015 - 09:52 PM
Ya Jeff, looks exactly like what I need, minus that weird upside down rake looking thing. What does that actually do, I can't say I have ever seen that arrangement?
#6 David Brown OFFLINE
David Brown
  • 4,403 Thanks
  • 2,385 posts
Posted September 06, 2015 - 09:55 PM
That is actually a home made potato plow that my brother whipped up.  Works pretty good.
I actually have one of these attachments that is not an A frame but it's the same general idea.  If I still have it, I'll send you a pic and see if it will work for you.  Might save you some work.
Edited by David Brown, September 06, 2015 - 09:57 PM.
#7 wvbuzzmaster OFFLINE
  • 4,496 Thanks
  • 7,345 posts
Posted September 06, 2015 - 09:59 PM
It looks like it would dig potatoes nicely, sifting them from the dirt. Any chance your brother designed that while raking leaves? Lol
#8 David Brown OFFLINE
David Brown
  • 4,403 Thanks
  • 2,385 posts
Posted September 06, 2015 - 10:01 PM
I never know what's going through his head but he builds some good stuff.
#9 KennyP ONLINE
  • 29,487 Thanks
  • 40,461 posts
Posted September 07, 2015 - 06:00 AM
I built one here!
  • Alc and wvbuzzmaster have said thanks
#10 David Brown OFFLINE
David Brown
  • 4,403 Thanks
  • 2,385 posts
Posted September 07, 2015 - 08:27 AM
I built one here!
Casey, this has become your best choice as I have checked this morning and found that I no longer have what you need.  I thought for sure I did.  Sorry Bud, I would have given it to you.  I think Kenny has everything you need to be successful in this venture.  Should you need any other measurement, just let me know and I'll do what I can.  Good luck.
Will you be at the Marburger plow day later this month?
Edited by David Brown, September 07, 2015 - 08:28 AM.
#11 victor3ranger OFFLINE
victor3ranger
  • 311 Thanks
  • 617 posts
Posted September 07, 2015 - 09:13 AM
David,
what in the world is that thing on the back?
Never mind, I see that you already answered that question. Neat tool. Would you want to make another one ?? :D
Edited by victor3ranger, September 07, 2015 - 09:16 AM.
#12 David Brown OFFLINE
David Brown
  • 4,403 Thanks
  • 2,385 posts
Posted September 07, 2015 - 09:34 AM
David,
I would but the one you see was made by someone far more handy than myself.
#13 sodisr OFFLINE
sodisr
  • 657 Thanks
  • 768 posts
Posted September 07, 2015 - 10:02 AM
Casey,,,   I built one just like Kenny has  pointed out ..  You can get the pins at most tractor supply houses. I did have to score the bends half way throu with a hack saw to make the bends crisp and strait ,,then weld the cuts back up.. I tried without making the cuts and when I heated them to bend,, they bent crooked...   Hope this helps...
   PS,,, Ballard also makes them.
#14 wvbuzzmaster OFFLINE
  • 4,496 Thanks
  • 7,345 posts
Posted September 07, 2015 - 11:46 AM
Is that the one near Evans City, Pa on Sept 26?
If so I am thinking about it right now. As for reality, we will see. I would like to take the New Holland, but if I don't get the three point on and the ag tires it won't be there. However, the Farmall Cub is always ready to roll, if I actually decide to go.
#15 wvbuzzmaster OFFLINE
  • 4,496 Thanks
  • 7,345 posts
Posted September 07, 2015 - 11:55 AM
I built one here!
Dang Kenny, I won't be able to hold such a high standard like you lol.
