Tow Attachment
21 replies to this topic
#16 MH81 OFFLINE
  • 29,978 Thanks
Posted September 06, 2015 - 09:41 PM
There are some ideas in this thread.
http://gardentractor...ge-1#entry47828
Mine hasn't been on a tractor in over a year.
Didnt need it and now that the FEL is in my life...
  • wvbuzzmaster, KennyP, boyscout862 and 1 other said thanks
#17 bbuckler OFFLINE
bbuckler
  • 3,763 Thanks
  • 3,270 posts
Posted September 06, 2015 - 09:45 PM
I need to add another buzzbox to my Christmas list.
#18 KennyP ONLINE
  • 40,901 Thanks
  • 47,101 posts
Posted September 07, 2015 - 06:08 AM
Many thoughts, but the hand lift makes it in the KISS area. Not sure if I can get the point across here, but I'll try. Make up a small trailer frame type thingy. Behind the axle put a couple arms that go under the axle of what you want picked up. Use it similar to what is used to lift a motorcyle rear wheel and attach to the tractor.
  • bbuckler said thank you
#19 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted September 07, 2015 - 10:51 AM
I don't want to hyjack this thread,,, But,,,  is there anyway to put a door  or  gate hinge on the tow pin ,, and have a channel stock welded to the hinge,, and let a  sleeve hitch lift it.??
    I run into ,,sometimes I need to tow a log and the nose drags into the ground.. this would at least pick the front of the log up a few inches and thus,, less drag.. and grooves in the lawn..??
#20 KC9KAS ONLINE
KC9KAS
  • 5,464 Thanks
  • 4,722 posts
Posted September 07, 2015 - 12:39 PM
I use a strap and my 12 year old.
Dad used one of those on me for years
#21 MH81 OFFLINE
  • 29,978 Thanks
Posted September 07, 2015 - 12:56 PM
With the log, a log arch is best IMO
Like this one that grnspot110 made for example
  • sodisr said thank you
#22 JBRamsey OFFLINE
JBRamsey
  • 1,568 Thanks
  • 878 posts
Posted September 07, 2015 - 03:30 PM
I get it. This sounds like the things that HF sales for moving a trailer around by hand. Roll it under the axle, push down on the tongue and it lifts the front of the tractor and then hook it to your pulling tractor. Couldn't be simpler. Get a couple of cheap wheels and a stick of square tubing and you're in business.
  • Alc, lesmeister and bbuckler have said thanks
