Can I make pdf off my scanner?
5 replies to this topic
#1 glgrumpy OFFLINE
  • 8,616 Thanks
  • 7,923 posts
Posted September 05, 2015 - 08:30 PM
Puter dummy here, so "talk" easy w/out the terms I don't know. I have some Speedex files that are rough to read. I can see them if I put under my mag light. They are kinda weak and small, downloaded from net and surely not orig there either. SO.....thinking if they were pdf files I could enlarge and print as wanted and take to garage to work off of. CAN I scan off my scanner to be a pdf file? THEN, how is it saved?  Do I have to put on CD or a thumb drive? Or can it just be saved in a file on puter, and then which one?  I have a scanned items file now, does it just go there as others and then open the pdf program when needed to see? I'm not sure Where to go to pick pdf file if I can do that, on the puter.
#2 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted September 05, 2015 - 09:05 PM
I guess a lot depends on your particular scanner.
My scanner has a pdf button to press to create a pdf file.
#3 MH81 OFFLINE
Posted September 05, 2015 - 10:49 PM
The PDF may or may not be your answer, but to answer the question... Normally yes.
There is either a button on the unit or you have to use the software that came with the scanner to do it.
#4 KennyP OFFLINE
  • 38,418 Thanks
  • 45,945 posts
Posted September 06, 2015 - 07:11 AM
I can do that with my scanner, but the option is in the software on the computer.
#5 lrhredjb OFFLINE
lrhredjb
  • 699 Thanks
  • 572 posts
Posted September 06, 2015 - 09:22 AM
If the document you are scanning is low resolution being able to make it bigger is not going to help much.
#6 Trav1s ONLINE
Trav1s
  • 3,310 Thanks
  • 4,365 posts
Posted September 06, 2015 - 11:58 AM
An option to consider is scanning it to a high-res file then printing it to PDF using CutePDF.  I have been using this application for over 10 years without a problem.  Used it on Win2k, XP, and 7 so far.
http://cutepdf.com/P...ePDF/writer.asp
Edited by Trav1s, September 06, 2015 - 11:59 AM.
  • sodisr said thank you
