just got to thinking
thanks a lot earthgrinder....
12 replies to this topic
#1 stubbysteve OFFLINE
stubbysteve
  • 54 Thanks
  • 107 posts
Posted September 04, 2015 - 11:08 PM
Just got to thinking after reading a post made by earthgrinder. Since I don't have legs and am bound to a wheel chair for mobility, my DB walker won't be used for actual ground work. Just more of a show type tractor.
But for those of you that have a walker, reguardless of brand, and have a ride on sulky, how hard are these to actually steer? And I mean like on grass or asphalt. I do how ever still till my own garden with my rear tine new style tiller. And it is a pain in the butt cause you have to hold it up in the rear when transporting it from the shed to the garden.
I am aldo thinking of maybe making a hitch on the back of my sulky or making another cart to maybe actually use one in the garden or just to play with some.
So really are these a pain in the butt to steer? Thanks.
  • oldedeeres said thank you
#2 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,720 Thanks
  • 4,220 posts
Posted September 05, 2015 - 01:41 AM
I think, a four wheeled walk behind won't work. Better is a two wheeled like this, for transporting aso.
  • Gtractor and boyscout862 have said thanks
#3 stubbysteve OFFLINE
stubbysteve
  • 54 Thanks
  • 107 posts
Posted September 05, 2015 - 01:50 AM
Yep thats what I was talking about. The 2 wheel walk behind
#4 karel OFFLINE
karel
  • 1,922 Thanks
  • 1,296 posts
Posted September 05, 2015 - 07:29 AM
I don't think so. Just have enough room to make a wide turn.And one that has reverse!
  • boyscout862 and oldedeeres have said thanks
#5 stubbysteve OFFLINE
stubbysteve
  • 54 Thanks
  • 107 posts
Posted September 05, 2015 - 08:36 AM
Mine does have reverse as well as the speed chainger. I also down loaded the optional brake manual and hopefully I can replicate it am that way I can have good enough brakes.
  • Lauber1 and karel have said thanks
#6 lrhredjb OFFLINE
lrhredjb
  • 621 Thanks
  • 532 posts
Posted September 05, 2015 - 09:13 AM
Pretty long wheelbase on that rig in the photo. Would be like turning an aircraft carrier around. :D
#7 Gtractor OFFLINE
Gtractor
    The Tractor Hoarder
  • 8,939 Thanks
  • 4,830 posts
Posted September 05, 2015 - 10:27 AM
Most generally they steer hard, requiring more effort than a regular riding tractor.  A lot of that is determined by tires.  I have some 2-wheelers on steel with lugs and they are brutal to turn if they don't have turning brakes.   Yes with such long handlebars you get decent leverage to turn and your pneumatic tires will help a bunch.
Also, if you were pulling a heavy load the hitch wants the tractor to pull straight.  Just pulling a cart around the yard won't be too bad.
 As mentioned above, they definately do not turn very sharp.  Most two wheelers with riding sulky have the turn radius of a train.
jd.rasentrac,  4 wheeled walk behinds do work if they are zero-turn!  :poke:
We have an amish community close by and they use Dixon zero-turns with the seats removed and very primitive homemade linkages to move the controls to the back of the mower.
Then they can walk behind because eeeeeveryone knows you can't get into Heaven if you drive something with an engine.  :(
Edited by Gtractor, September 05, 2015 - 10:28 AM.
  • Lauber1 and HANKG have said thanks
#8 diesel nut ONLINE
diesel nut
  • 679 Thanks
  • 417 posts
Posted September 05, 2015 - 11:45 AM
I have a David Bradley I made a sulkey for with a little bed on the back and it's ok to steer but if you try to make a sharp turn the handle bars get you in the upper leg and hip area.  Gravely made one that bolted solid to the frame and had a steering wheel so the wheels under the seat turned and it acts kid of like a zero turn.  From what I've heard from people that used both styles on the Gravely they prefer the steering one better.  Hope this helps.        Stewart
  • Lauber1 said thank you
#9 framesteer OFFLINE
framesteer
  • 405 Thanks
  • 194 posts
Posted September 05, 2015 - 03:03 PM
I have seen sulkies with steerable wheels (using foot rest controls). Greatly improves maneuverability.
#10 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,476 Thanks
  • 2,811 posts
Posted September 05, 2015 - 04:09 PM
im thinking maybe you miss the part of him having no legs?
  • Gtractor said thank you
#11 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,476 Thanks
  • 2,811 posts
Posted September 05, 2015 - 04:16 PM
maybe you should think outside the box here , and look at the fact most trouble with sulkies is hitting your knees on the handles of the tractor. No offence, but not having legs would be an asset is this department. Look into making a sulky that will accept your scooter, wheelchair or which ever mobility device you use. Sort of like a chariot, then drive up inside it. to control the tractor. you can figure out the tooling to push/pull after you get past the mobile part.
  • diesel nut said thank you
#12 stubbysteve OFFLINE
stubbysteve
  • 54 Thanks
  • 107 posts
Posted September 05, 2015 - 09:24 PM
Guys im really way outside the box.I build motorcycles, lawn mowers climb deer stands etc. I think I will be ok. Thanks for the input fellas.
#13 karel OFFLINE
karel
  • 1,922 Thanks
  • 1,296 posts
Posted September 06, 2015 - 07:08 AM
It is!
