Briggs 14 hp coil problem
4 replies to this topic
#1 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted September 02, 2015 - 01:21 PM
I have simplicity 3314h and when I got it most of wiring was unhooked and points were gone I figured out they were not there when I jumped the solenoid to see if it would fire and had no spark I put a set of points and condenser on and got it to fire and run by jumping the solenoid so I hooked up the rest of the wires and found a white one was cut after looking at the wirin diagram and some help I figured out it went to a plastic tab the mounts to points cover when I tried to start it with the key smoke came out from the engine tin so I pulled the motor and took the cover off and found the sorce was the coil any idea as to y this happened thank you for any help
#2 Bolens 1000 ONLINE
  • 14,978 Thanks
  • 18,136 posts
Posted September 02, 2015 - 01:27 PM
What model engine? Are you using a magnet type coil or 12vt automotive style coil?
#3 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted September 02, 2015 - 09:37 PM
Here is the numbers off the engine tin and a picture of the coil 320421-0134-01-700729
#4 ACmowerguy OFFLINE
ACmowerguy
  • 392 Thanks
  • 361 posts
Posted September 07, 2015 - 12:56 PM
Did someone recently put a different ignition switch on it?
#5 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted September 10, 2015 - 09:57 AM
As far as I can tell it looks to be the original ignition switch
