J D 316 no spark
4 replies to this topic
#1 Nicky1 OFFLINE
Nicky1
  • 25 Thanks
  • 9 posts
Posted September 01, 2015 - 04:24 PM
I have a JD 316 with an Onan engine.  Tractor Model is Moo316X011224. Engine model is P218C T/10462C.
 Engine serial # C903669024.. It just stopped when mowing the grass . I found it had no spark to the plugs. I checked the voltage at the coil and had 10.5 when cranking. I checked the coil resistance and had 3.2 ohms on the primary and 18,000 ohms between the plug wire sockets in the coil. I don't know where to go from here as this is the first Onan I have worked on. Information on the Web seems hard to find. Any help greatly appreciated. Thanks in ad
#2 Bud W OFFLINE
Bud W
  • 315 Thanks
  • 297 posts
Posted September 02, 2015 - 09:48 AM
Do a search for "Troubleshooting Onan Ignition", there's good info  and pics on how to check the coil and trigger function.
  • Nicky1 said thank you
#3 Bud W OFFLINE
Bud W
  • 315 Thanks
  • 297 posts
Posted September 02, 2015 - 09:51 AM
Sorry, Google search "onan ignition troubleshooting images".
#4 motobreeder OFFLINE
motobreeder
  • 433 Thanks
  • 618 posts
Posted September 02, 2015 - 11:14 PM
Welcome to the forum.
Hope folks have good suggestions for you.
Make sure the points are still closing making a good connection.
My Case with a Kohler 14hp shut down while cutting grass one day.  One of the leads to the coil was broken.
It had failed inside a connector so it wasn't easy to see right away.
#5 Onanparts OFFLINE
Onanparts
  • 94 Thanks
  • 41 posts
Posted September 04, 2015 - 11:49 AM
You can download the service manual here. http://gardentractor...service-manual/
See section 8 for ignition troubleshooting/testing. P218 will have electronic ignition, no points.
