Redneck repair or pure genius your call
cable repair
19 replies to this topic
#1 Buck Tales OFFLINE
Buck Tales
  • 187 Thanks
  • 122 posts
Posted September 01, 2015 - 04:16 PM
Well all was well until I went to speed up the motor and WHAM, the throddle cable breaks. Cut my day short and to boot getting a new cable for a  1969 tractor is not going to be a quick run to the local auto parts store for sure. If I can even find 1 I figure I will have to wait a couple of days and get a used one in who knows what shape to boot. So on goes the thinking cap, now how can I fix a broken cable? Well both ends were moving free but it broke right in the middle. I looked at both ends and the cable had 2 "Z" bends to fit each end into the lever and the carb arm. BINGO, this cable looks like a bit larger than .035 mig wire. Out comes the cable assembly and I removed the old pieces from the sheath. Next I sprayed the liner sheath with some lube and inserted the mig wire piece I cut from the roll. It fit with room to spare and that mig wire is tough too. Next I bent the ends with needle nose pliers to make the "Z" bends. WALA, perfect fit and I was up and running again in under an hour. If you got the old sheath liner and can get the cable out of the inside this is a great way to do your own cables I believe. The one pick shows the roll of mig wire I ran off the machine and another shows the end I left long for the carb connection until I had it in place. The lever even works easier than before and all that stiff movement is gone. How sweet it is.
  • olcowhand, Gtractor, limebuzz and 24 others have said thanks
#2 Gtractor OFFLINE
Gtractor
    G-agressive tractor
  • 9,328 Thanks
  • 4,954 posts
Posted September 01, 2015 - 04:25 PM
If it holds up long term,  it can't be anything but genius.  :thumbs:
  • Alc, jimbobbillyray and Buck Tales have said thanks
#3 CanadianHobbyFarmer OFFLINE
CanadianHobbyFarmer
  • 1,178 Thanks
  • 697 posts
Posted September 01, 2015 - 04:41 PM
Good thinking. I take it that is solid wire not flux core? I have a gasless Mig and the wire seems to break easily if bent. I do have a roll of electric fence wire that would likely work though.
  • KennyP, Buck Tales and ChrisF have said thanks
#4 classic OFFLINE
classic
  • 5,209 Thanks
  • 2,248 posts
Posted September 01, 2015 - 04:45 PM
It's hard to find people that can think outside the box these days. Good thinking on the repair. Lots of people would have called it a day and waited for a new part. We have a hard time finding people who can improvise in the industry that I'm in. I had to make a guide roller for a track feeder when one of ours fell apart. I used an old cable pulley from a crane, a worn drive sprocket from one of our bucket elevators, and a length of shaft. The roller held up until the new replacement arrived. It's a blast making something work with what you have laying around. I think there are over 1,000 uses for welding rods other than using them for welding, HA!
  • MH81, boyscout862, oldedeeres and 2 others have said thanks
#5 Bolens 1000 OFFLINE
  • 14,987 Thanks
  • 18,140 posts
Posted September 01, 2015 - 04:54 PM
Thats quite the repair!
I do sell cables and inner wire by the foot if you ever run into problems with it
  • MH81, HDWildBill, boyscout862 and 2 others have said thanks
#6 EricFromPa OFFLINE
EricFromPa
  • 3,658 Thanks
  • 3,113 posts
Posted September 01, 2015 - 05:06 PM
Good stuff there.
I got a couple push mower cables that I keep just in case.Even though the plastic outer part is junk I keep them for the Cores.I gota do the same thing to the old sears if I can get the cable out.It's froze.A little oil and a wiggle should loosen it up.
  • Traill95 and Buck Tales have said thanks
#7 oldedeeres ONLINE
oldedeeres
  • 9,502 Thanks
  • 4,769 posts
Posted September 01, 2015 - 06:21 PM
Pure genius = common sense thinking. Well done!
  • Buck Tales said thank you
#8 tater195 ONLINE
tater195
  • 2,196 Thanks
  • 1,411 posts
Posted September 01, 2015 - 06:23 PM
Ditto on the flux core thing. If it was, I am surprised you got the bend in it
#9 Buck Tales OFFLINE
Buck Tales
  • 187 Thanks
  • 122 posts
Posted September 01, 2015 - 06:29 PM
No flux core, it was solid wire from a gas machine. It does work quit well and I figured if the original lasted since 1969 I should be able to get at least a couple years from this one. Besides it is the throdle cable which does not take a great deal of pressure to pull. I'll keep you guys updated if it fails in the next couple of years. :wave:  :rolling:
#10 chieffan ONLINE
  • 10,136 Thanks
  • 6,635 posts
Posted September 01, 2015 - 06:57 PM
I have done about the same thing using stainless steel wire in 36" lengths.  Bought a box full of .045 many moon back when I was building the bass lure called a spinner bait.  Had not found their way up north to Iowa but were used a lot down in Southern MO, Ar, Etc.  Made a truck load of them and some good money on the side.
  • oldedeeres and Buck Tales have said thanks
#11 dthomp17 OFFLINE
dthomp17
  • 587 Thanks
  • 472 posts
Posted September 01, 2015 - 06:58 PM
You've got my vote for genius.  I've even surprised myself at some things I've come up with for a temporary fix that actually turned out to be semi permanent.  Hope it holds up for at least two years and I believe it will.
#12 KennyP ONLINE
  • 38,352 Thanks
  • 45,921 posts
Posted September 01, 2015 - 07:04 PM
Great fix! I usually just go get a universal choke kit and fix mine!
  • 1oldbuzz and Buck Tales have said thanks
#13 MH81 OFFLINE
Posted September 01, 2015 - 07:29 PM
Nice job getting going in a hurry.  Keeping that Farmer Fixing Gene alive and well :thumbs:
#14 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted September 01, 2015 - 07:46 PM
Yes I always have a few pieces of music wire in the shop. I have made a set of wire size pin punches, by drilling holes in the center of brass rods and holding the wire with set screws.
#15 MolonLabe OFFLINE
MolonLabe
    Rust Wrangler
  • 551 Thanks
  • 320 posts
Posted September 02, 2015 - 06:16 AM
Pure genius, I probably would have bought a piece of wire without even thinking about my mig. Good job.
