1949 Waterloo Bronco no spark
garden tractor
16 replies to this topic
#16 Links56 OFFLINE
Links56
  • 14 Thanks
  • 11 posts
Posted September 03, 2015 - 10:16 AM
If you have a push button starter you will probably have another switch to put power to the coil. whatever side of the battery is ground, (in your case the pos post) that is the post of the coil that goes to the points. The other side should have power when the key is on. The big coil wire in the center goes to the cap. If you are using a 12v test light on a 6v system, the light will be real dim. I don't like flashing the wire at the battery. Creating a spark near the battery is a good way to blow it up in your face. Not a good time!!
That's true but unless the battery is being charged there is no risk of it exploding. Next time hook the wire to the battery and touch it to the post.
#17 Wheelboy OFFLINE
Wheelboy
  • 21 Thanks
  • 29 posts
Posted September 03, 2015 - 11:21 AM
Ok got it running. The wire to kill switch Was toast. Thanks for your help everyone
Now to fix the lights!
Also tagged with one or more of these keywords: garden tractor
