K321 breaker point plunger pin
4 replies to this topic
#1 coinman66 OFFLINE
coinman66
  • 182 Thanks
  • 296 posts
Posted August 31, 2015 - 03:14 PM
My JD 214 is getting no spark at the plug, so while turning engine over I noticed breaker points were not opening. Guess it's that little plunger pin thing. So how do I remove and replace it? I just hope the lobe on the cam isn't wore or grooved down.
  • chieffan said thank you
#2 Bolens 1000 ONLINE
  • 15,444 Thanks
  • 18,290 posts
Posted August 31, 2015 - 03:16 PM
Once the points are removed the pin should pull right out
  • boyscout862 and chieffan have said thanks
#3 LilysDad OFFLINE
LilysDad
    Anything Red . . .
  • 14,149 Thanks
  • 10,210 posts
Posted August 31, 2015 - 03:27 PM
The pin used to be made of steel. The new ones are aluminum. If at all possible find one of the steel ones.
#4 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,276 Thanks
  • 6,083 posts
Posted August 31, 2015 - 03:45 PM
If the plunger isn't moving in and out the cam may be FUBAR..
#5 BigFlash OFFLINE
BigFlash
  • 248 Thanks
  • 134 posts
Posted August 31, 2015 - 06:32 PM
If possible, i would pull the points off, hold pressure against the pin with your finger and turn the engine over by hand,  Should you let if know if the cam moves at all, and and will let you feel if anything unsavory is going on inside.  I suggest using a the flywheel nut or the pto end bolt, if you turn it by the flywheel itself, it might hide a broken flywheel key.
