V4 10 magneto wire
2 replies to this topic
#1 OldShu OFFLINE
OldShu
  • 6 Thanks
  • 9 posts
Posted August 30, 2015 - 10:05 PM
Another question ,Guys. I know the engine runs independently of battery. Battery is for the starter and any accessories. So, without appearing too stupid, may I ask the the guys who know, where does the wire marked "M" on the key switch run to? It carries voltage ,but why is it marked for magneto if theres no place to connect it and the magneto creates its own charge. When I got this tractor this wire from the switch was just dangling and I don't see any purpose for it. Any help would be greatly appreciated.
#2 boyscout862 ONLINE
  • 13,446 Thanks
  • 9,392 posts
Posted August 30, 2015 - 10:27 PM
It may be the wrong switch. Check the wiring diagram in the manual. Good Luck, Rick
This is probably the closest. http://gardentractor...h-hog-tractors/
Edited by boyscout862, August 30, 2015 - 10:30 PM.
  • OldShu said thank you
#3 boyscout862 ONLINE
  • 13,446 Thanks
  • 9,392 posts
Posted September 04, 2015 - 10:31 AM
I didn't think that "M" should be hot. It should be grounded when the key is in the "off" position and an open circuit when it is in the "run" position.  Look at this thread:   http://gardentractor...ignition switch  .
If you have a coil you would need an "I" terminal on the switch to go to the coil. It would be hot for the ignition to work. Post some pics of the tractor, engine switch and wiring.  Good Luck, Rick
This manual for a D4-10 shows a 3 prong switch on page 16.  http://gardentractor...d-parts-manual/
Edited by boyscout862, September 04, 2015 - 10:47 AM.
