Briggs points plunger
7 replies to this topic
#1 Banjo123 OFFLINE
Banjo123
  • 17 Thanks
  • 72 posts
Posted August 30, 2015 - 09:04 AM
today I noticed oil running down the engine block on my 1965 wards squire 10. It's coming from the points plunger. I've watched zippo Vargas video on this subject and it's very helpful but I still have questions. Can the crank and cam stay in the engine? And where can I get a plunger, bushing, and the little boot needed to do this? Thanks!
#2 Bolens 1000 OFFLINE
  • 14,906 Thanks
  • 18,104 posts
Posted August 30, 2015 - 09:12 AM
Sounds like a worn bushing , most parts are still available for B&S engines what model engine is this?
#3 Banjo123 OFFLINE
Banjo123
  • 17 Thanks
  • 72 posts
Posted August 30, 2015 - 09:42 AM
I'll have to look. I know it's a 10 horse. Maybe a 23d. I'll check. So I can go to a briggs dealer?
#4 Bolens 1000 OFFLINE
  • 14,906 Thanks
  • 18,104 posts
Posted August 30, 2015 - 11:43 AM
If you have your engine numbers they should be able to help you locally, I also carry genuine briggs parts  if you cant find anything locally
#5 boyscout862 OFFLINE
  • 12,550 Thanks
  • 9,044 posts
Posted August 30, 2015 - 11:44 AM
It should be a 243341 B&S engine but who knows what may have been put in as a replacement over the past 50 years. Read the B&S Repairmans manual. There is a section on how to replace the bushing and plunger. There is also a seal kit that can be added on. I would try the seal kit first. Several of our sponsors can get them.  Try this guy  https://bolenspartsandsupplies.com/  (he posted above). Good Luck, Rick
I've found my local guys are more expensive than our sponsors.
Edited by boyscout862, August 30, 2015 - 11:46 AM.
#6 Banjo123 OFFLINE
Banjo123
  • 17 Thanks
  • 72 posts
Posted August 30, 2015 - 06:24 PM
So I may just need a seal as opposed to the bushing and plunger? I think it seems to be seeping pretty badly. Im no expert though.
Edited by Banjo123, August 30, 2015 - 06:28 PM.
#7 Bolens 1000 OFFLINE
  • 14,906 Thanks
  • 18,104 posts
Posted August 31, 2015 - 07:04 PM
When you get a chance to read the model number I can let you know the options available for your engine.
#8 Banjo123 OFFLINE
Banjo123
  • 17 Thanks
  • 72 posts
Posted September 01, 2015 - 10:42 AM
Ok. I'll get those when I come back into town.
