of having to use limiter straps on either the deck cylinder, or 3pt
cylinder in order to use one or the other. It's just not
user friendly.
With Tudors help, we accomplished that by putting a 12v solenoid
valve on board to activate the 3ph cyl. That is on my MF16, and
is working fine. Using other parts I have laying around, I'd like
to try a bit of a different approach for a 3pt for my MF14 worker.
Bob, since one of your projects is in the rough,(:rolleyes:) hopefully you'll
have a moment to cipher this.
Here is a picture of the valve I have, and a really rough sketch
of my idea.
The valve is a 12volt, 3 way, 2 position.(from the Eaton code decipher)
There is another port below the "20197A"
