Need to find TDC on John Deere 214
10 replies to this topic
#1 coinman66 OFFLINE
coinman66
  • 182 Thanks
  • 296 posts
Posted August 27, 2015 - 03:14 PM
How do u find TDC on a model 214 with a Kohler K321 engine? Trying to set gap in breaker points. I assume it's .020 for starters? U do have to do this at top dead center right?
#2 boyscout862 ONLINE
  • 13,552 Thanks
  • 9,427 posts
Posted August 27, 2015 - 03:20 PM
Download the Kohler manual from our Manuals Section. Good Luck, Rick
#3 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,266 Thanks
  • 6,071 posts
Posted August 27, 2015 - 03:47 PM
Just turn the crankshaft until the points gap is the largest..  (IE-  just before they start to close)  Make sure they are clean as well and set them to .020"..  Good luck!
Edited by WNYTractorTinkerer, August 27, 2015 - 03:48 PM.
#4 Bill 76 OFFLINE
Bill 76
  • 2,011 Thanks
  • 1,207 posts
Posted August 27, 2015 - 03:55 PM
Do it like Tinkerer said above----you don't want it to fire at TDC
#5 coinman66 OFFLINE
coinman66
  • 182 Thanks
  • 296 posts
Posted August 27, 2015 - 05:20 PM
Sounds simple enough. Thanks!
#6 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,139 posts
Posted August 27, 2015 - 05:49 PM
If the machine is parked level, it should be the highest point of the steering wheel.
  • LilysDad and WNYTractorTinkerer have said thanks
#7 coinman66 OFFLINE
coinman66
  • 182 Thanks
  • 296 posts
Posted August 27, 2015 - 08:00 PM
I like it!
#8 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,117 Thanks
  • 10,188 posts
Posted August 27, 2015 - 08:30 PM
I've never seen someone put themselves out to help like Cat does. What a guy! :thumbs:
  • larrybl and shorty have said thanks
#9 shorty ONLINE
shorty
  • 5,833 Thanks
  • 5,415 posts
Posted August 28, 2015 - 04:40 AM
Someone must have gave some good kitty treats, maybe tuna. Who took away the nip?
#10 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted August 28, 2015 - 05:34 AM
There is a timing mark on the flywheel and a hole in the engine cover to view it, but it's usually impossible to see it without cleaning the flywheel and painting the mark white so it shows up.
  • Trav1s said thank you
#11 Trav1s ONLINE
Trav1s
  • 3,578 Thanks
  • 4,554 posts
Posted August 28, 2015 - 07:37 AM
I have always used this approach without problems.
