Need JD Wiring diagram
5 replies to this topic
#1 TAHOE ONLINE
TAHOE
  • 7,315 Thanks
  • 5,359 posts
Posted August 25, 2015 - 07:42 PM
Anyone have the manual for a JD 425? My coworker has one with an electrical problem and since our site can no longer host the manual, I need a good complete tractor wire diagram if anyone has it.
Thanks
#2 Username OFFLINE
Username
  • 2,069 Thanks
  • 1,425 posts
Posted August 25, 2015 - 09:14 PM
There are lots and lots and lots of pages of wiring diagrams and I think for at least two different serial numbers for the 425 tractor.What problem is it having?
#3 daniel_b OFFLINE
daniel_b
  • 20 Thanks
  • 27 posts
Posted August 25, 2015 - 09:36 PM
TAHOE,
i may not feel that the price of green paint is worth what they want for it, but they are pretty good about their manuals, start here:
John Deere technical manuals
http://www.deere.com...chServlet?tM=FR
i put in: 425
http://www.deere.com...h&submit=Search
at the above, you can play a bit more knowing the particulars...
i've always found a lot here:
http://www.wfmachine...orums/forum.php
or when all else fails:
JD 425/wiring diagram
http://www.google.co...TF-8&gws_rd=ssl
the first response is:
John Deere 425, 445 and 455 Technical Manual
http://www.mytractor...cal-manual.html
07-10-2009, 11:35 PM post #1 of 1
simple_john
http://www.mytractor...RE425445455.pdf
 @ 69 meg
NOTE:
to see if someone has ever posted what you are looking for at a particular site, you can do a "site" search using the following formula:
John Deere 425 wiring diagram site:http://gardentractortalk.com
just substitute after the colon whatever site you want to search...
be safe,
daniel
#4 TAHOE ONLINE
TAHOE
  • 7,315 Thanks
  • 5,359 posts
Posted August 26, 2015 - 06:58 AM
He is finding wiring diagrams, but when he tries to save and print, most print out small and unreadable. All other manuals is "pay to play", he's not ready to do fork it over yet.  He's not super computer literate and I haven't had time to look for him yet so I may still be able to find it myself.
He said his son was cutting grass and as he came up a hill it started bogging down then smoke starting coming out from under hood, said it smelled "electrical" . Tractor stalled then would not turn over at all. I've had him jump the battery directly to starter and it spins so looks like it's not a starter problem.  They also checked the "start" wire from the switch on the side of solenoid, but have no voltage so they need a diagram to see how all the safetys and wires run to track where the breakdown has happened. I think it's a fuse somewhere, but I am JD illiterate so not much help  :D
Daniel, I did a site search and there was on this site at one time, but had to be removed due to a "letter from JD lawyers" and copy write laws.
I did see that MTF download last night, but he can download it to his computer, that's 69 megs, ouch.
Edited by TAHOE, August 26, 2015 - 07:01 AM.
#5 Username OFFLINE
Username
  • 2,069 Thanks
  • 1,425 posts
Posted August 26, 2015 - 08:26 AM
There are 3 fuses on the key switch module on the right side under the dash.
I am getting ready to leave for Portland show and will be going out 70 later today,I could bring my manual along and you could use it if someone wanted to meet me along the way.
#6 TAHOE ONLINE
TAHOE
  • 7,315 Thanks
  • 5,359 posts
Posted August 26, 2015 - 11:49 AM
Thanks for the offer. We did find a printable wiring diagram this morning, hope it will help him.
After I looked at it, I told him it was above my pay scale, too many circuits and a circuit board.
