Brush, roller or spray, what do you use........
17 replies to this topic
#1 propane1 ONLINE
propane1
  • 9,481 Thanks
  • 4,411 posts
Posted August 25, 2015 - 05:44 AM
On your house or garage when you paint. I am looking for your opinions. Which is your choice, pros and cons. I am using water based paint. I have used all three methods. Just wondering what you all think. Noel
  • hamman said thank you
#2 toppop52 OFFLINE
toppop52
  • 5,548 Thanks
  • 4,907 posts
Posted August 25, 2015 - 06:13 AM
Siding... :D
  • boyscout862, Buddy, petrj6 and 1 other said thanks
#3 KennyP ONLINE
  • 41,013 Thanks
  • 47,164 posts
Posted August 25, 2015 - 06:27 AM
I use mostly spray & brush the trim colors! I have a Graco sprayer.
  • boyscout862 and propane1 have said thanks
#4 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 10,942 Thanks
  • 6,390 posts
Posted August 25, 2015 - 06:31 AM
Brush.  Everytime I've seen a house sprayed the paint doesn't stick and eventually peels off in sheets.  Maybe that's poor prep work ect, but for that reason I won't spray.
#5 chieffan ONLINE
  • 11,412 Thanks
  • 7,139 posts
Posted August 25, 2015 - 06:52 AM
I agree.  ONLY way to get a good spray job is to use the spray to put the paint on and a good brush to work it in.  Spray put the pain on, not in.  22years ago I brush painted a 2 story Victorian house I owned in town.  Used True Value's best paint. Painted a beige over lead based barn Red one coat and no primer.  It is now ready for a new coat of paint.  So the only way to put paint on is by Brush as far as I am concerned.
  • boyscout862, toomanytoys84 and propane1 have said thanks
#6 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,282 Thanks
  • 6,086 posts
Posted August 25, 2015 - 06:53 AM
Vinyl siding!!  Brush for the window frames..
#7 HANKG OFFLINE
HANKG
  • 6,597 Thanks
  • 3,530 posts
Posted August 25, 2015 - 06:56 AM
Vinyl IS FINAL
#8 BTS OFFLINE
BTS
    Make Stuff Up
  • 4,643 Thanks
  • 2,618 posts
Posted August 25, 2015 - 07:08 AM
Painted the house last year and we used a spray gun, I guess we will see how long it last
#9 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,602 Thanks
  • 2,911 posts
Posted August 25, 2015 - 08:51 AM
Last Saturday in  4 1/2 hours we painted my BILs house and garage with an airless sprayer. Third time I've used a sprayer and it was well worth it. My son in law is a 3rd generation painter and he said that if the prep work is done right a sprayer is the best way to go with someone following up with a roller and small brush. 40' X 24' X 10' house and 36' X 28' garage and we used 10 1/2 gallons of water base paint / stain. SIL says his dad still prefers to brush and roll but with the advance with sprayers and labor and materials cost he says it's more efficient and cleaner to spray. JM2CW.   Good luck.        Roger
  • propane1 said thank you
#10 chieffan ONLINE
  • 11,412 Thanks
  • 7,139 posts
Posted August 25, 2015 - 08:53 AM
Vinyl IS FINAL
As long as it is white and no hail comes along.  The only thing that changes faster than vinyl siding colors is the weather.
#11 boyscout862 OFFLINE
  • 13,560 Thanks
  • 9,434 posts
Posted August 25, 2015 - 10:02 AM
Pressure wash first. The pressurewasher can then be used for GTs. I have preferred a brush when I have to paint but I put vinyl on my new house because I am getting to old to paint. Make sure it is clean and dry. Good Luck, Rick
#12 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 10,942 Thanks
  • 6,390 posts
Posted August 25, 2015 - 02:06 PM
On a sub note.
I used Valspar duramax paint on my house.
#13 KC9KAS OFFLINE
KC9KAS
  • 5,469 Thanks
  • 4,725 posts
Posted August 25, 2015 - 04:46 PM
Remember the story of "The 3 Little Pigs"...I use brick!  :thumbs:
#14 propane1 ONLINE
propane1
  • 9,481 Thanks
  • 4,411 posts
Posted August 25, 2015 - 05:45 PM
Thanks for all the info. I use a spray gun that you would spray a car with. I enlarged the outlet hole some to help it spray the thicker paint. I would say one of those air-less sprayers would be a good thing, as Hamman said. Any way, I am not one who realy enjoys painting the house. But when I am at it, it try and do the best job I can, with what I have to work with, including myself. Noel
#15 KennyP ONLINE
  • 41,013 Thanks
  • 47,164 posts
Posted August 25, 2015 - 06:57 PM
I've sprayed houses and 20 years later they still looked great! Might be the quality of the paint. Most box stores paint is junk!
